canon irc3220 blank display
  • etcopy1
    • 4
    I have a Canon irc3220 with a blank display. Green power light comes on only. Machine seems to warm up and make it a ready state. Tried different boot rom + memory. Have not tried a different hard drive because it seems not to error out. Tried different control panel. Checked all board connections. Any ideas?
  • SCREWTAPE
    East Coast Imaging
    • 3396
    Try the main controller
    • charm5496
      • 2387
      The HDD would have to be preloaded if you did try it as you could not reload it on this unit. You are on the right track with this issue as it usually a problem in the main controller box.
      • iRepair
        Make sure the contrast of the screen is not all way up.
        • Blues Guy
          • Aug 2009
          • 216
          Have come across these problem. Take out the RAM and BOOT Rom clean up the contact point with a contact cleaner and reseat back to the controller P.C.B. Or change the RAM
          • anothertech
            • 1756
            If it still doesn't work, try unplugging the main controller fan, it could be a bad fan. I could also be the fuse pcb, the sub main controller, or power distribution pcb.
            Also, check the wall outlet for a good neutral to ground.
            • sgcopiertech
              my experience with blank screen is always the power supply ( 4 of 4 machines)
              fortunately, for my case, soldering the dry joint behind the pcb always solves the problem.
