Anybody knows how many gram developer inside the IRC 3220 drum unit
  • hknwbec
    • 214
    Hi, Could anybody tell me how many gram developer inside the Canon IRC 3200/ 3220 drum unit. Do you have this figure.and could you tell me where can we have the assambly diagram of this unit. Thanks
  • mrfixit51
    Lead Service Technician
    • Oct 2008
    • 1975
    We do not have or need that information, my suggestion is for you to buy a new one, strip it apart and measure the developer mix weight. I assume you are looking to remanufacture drums... Most of us use Canon factory replacement drums.
    • hawa-s
      The weight of developer inside the IRC 3220 drum unit is 184 grs + 16 grs Toner
      • SCREWTAPE
        East Coast Imaging
        • 3396
        Very impress!
        But as Mrfixit stated,
        Why is there a need to know?
        • teckat
          • 16083
          The solid was dispersed into 3000 parts of an aqueous solution of 1 wt % sodium hydroxide and stirred well. The resultant solution was filtered to obtain the solid. Subsequently, the solid was dispersed into 1000 parts of an aqueous solution of 1 wt % sodium hydroxide, then stirred and filtered to obtain the solid.
          The solid thus obtained was washed with water and then dried so as to obtain 196 parts of the desired compound represented by the formula (III): ##STR3##
          • sercom_pub
            developer
            200 grms. because the complete bag come with 200 grams and who sellme thah dust tellme thah, I sell developer for irc3220 but is in mexico I refrubised the complete image unit drum, chip and developer
            • hknwbec
              • 214
              Is it workable, If you found any problem,please let me know,
              • teckat
                • 16083
                what the big Deal
                the Surface of the 3200/3220 Drum can not Refurbished/ once it's gone that's it
                • hknwbec
                  • 214
                  O no. just only for knowladge exchange, I had tried to change the drum cleaning material (brush )that we ordered from japan, it can improve the drum cleaning, but it is hard to install. Need patience.
