iR5570
  • toantam
    • 63
    iR5570
    Dear somebody!
    I've iR5570, it alway display replace toner cartrigde. But I'd changed develop sensor, hopper motor
    I can't solve my problem.
    Please give me some idea.
  • MrB
    • Nov 2009
    • 147
    What about the Deve unit itself, have you tried that yet
    And the easy one, try a different toner cartrigde..(I know, one of the 1st things to dol ol)
    • DadO
      • Dec 2007
      • 404
      Did u try to replace hopper sensor? I had a few problem when he fails but work and feed the toner form bottle to the hopper! Imagine that scene when u find more toner under machine then on paper
      Procedure that helps: Remove the toner form the developer and hopper. Clean the atdc sensors in dev and hop (or replace. I didn't have to) and run toner supply.
      • rad7845
        • Mar 2009
        • 6
        try replacing M9 and DC Controller
        • SCREWTAPE
          East Coast Imaging
          • 3396
          Does The developer fill when Toner-S is performed in Service Mode?
          You Might have a bad DC.
          • toantam
            • 63
            thank you so much!
            I'll try to change DC Controller, because last time I'd changed hopper, developer sensor, toner bottle.
            • Canuck
              Tech Specialist
              • 1713
              Simple question...does the bottle rotate?
