I have 2 of these and they are both doing the same thing they work connected to the IR-105
But when hooked up to the IR-8500 they boot up and come to idle and print a config page but the local network does not connect the little yellow light next to the cable is off. The cable is good the IR-8500 has up to date system software and the img is set on 4. does anyone know why this is happening ? Its driving me crazy trying to figure it out.I tried resetting to factoy default when hooked up to the 105,shut down and then hook up to the 8500 and run set up still the same thing.
