Canon IR2800 lead edge shading
  • dcsbiker
    • May 2025
    I have a couple machines in the field that have shading on the lead edge about 1/8" wide from top to bottom 1st copy only and it's intermittent. i've replaced the drum, turned down the pri charge & dv charge. that has worked in the past but not on these machine's.
    any ideas?
  • SCREWTAPE
    East Coast Imaging
    • 3396
    Is this when you make copies or when you print.
    • dcsbiker
      both copy and print
      • SCREWTAPE
        East Coast Imaging
        • 3396
        This is a rather simple machine. Trying replacing the transfer roller. Check the developer. I would put back all original values back.
        • dcsbiker
          I haven't tried the transfer roller.
