c5180 very light cyan
  • ReproKev
    • 273
    Only happens on cardstock. I can see the cyan is very faint (almost non-existent) on the itb belt during grad adj and copying/printing. Replaced cyan drum. Swapped yellow and cyan primary transfer rollers (inside itb assm). Upgraded system software to 84.01 (Dc Con v60). Cleaned out machine interior. All with no fix. 1 or 2 copies will occationally come out OK, but not many. Anyone ever see this?
  • SCREWTAPE
    East Coast Imaging
    • 3396
    It cloud be your card stock. Whats the Gms on that cardstock?
    • ReproKev
      • 273
      Standard 80lb cover and 67 lb vellum bristol. I have tried other stocks as well as "heavy 2" through the bypass and had the same problem. This is definately a problem of bad transfer, bad bias contact or something similar. I have another customer that has the same problem only with yellow and black (simultaneously) on 80lb hammermill color copy cover. Luckily the second customer has 2 machines and rarely runs card stock.
      Any chance there is an adjustment for low/high humidity like on the old CLC's? I didn't see any in the book or service mode.
      • SCREWTAPE
        East Coast Imaging
        • 3396
        Its seems like the primary transfer is not pulling the image off the drum. Why don't you try replacing those primary transfer rollers.
          • 16083
          remove CYAN primary transfer roller/ look in at the plastic end holders for C roller/ they crack and pressure springs can fall out on one or both ends, roller can slide out/once this happens roller is not butted to ITB belt for proper transfer/ something to overlook even when swapping rollers. !!!!!
          FS7-2782-000 8 springs
          FB6-2945-010 4 rear plastic bushings/holders
          FB6-2944-010 4 front " " "
          **extra ****Canon reports >there are some issues with drum drive assembly going bad/shows the symptom u mentioned washed out single color only on heavy paper/CQ ok on plain paper
          • ReproKev
            • 273
            Thanks for the replies. I did inspect and clean the primary plastic end holders as I was swapping them (I've seen that on c3200's). New transfer rollers are on order. I know the springs are in place but I may have missed a crack. I'll check again when I replace the transfer rollers.
            As far as the drum drive assm goes, is the fix to replace the entire drum drive assm? - Is it the "developing drive assm" FM2-5362 or "drum drive assm" FM2-5360? BIG price differance.
              • 16083
              First try this/ load card stock in bypass tray/ select plain paper on control paper/ and print five pg10 test prints/ inspect.
              If you have wash out on all colors on ITB unit when u select heavy mode, I would look in at ITB Drive Motor M1
              You said it is on only one color ????
              Canon Tech Pub quotes "While printing or copying with Heavy Media selected the magenta portion of the document would intermittently drop out". rep.= Drum Drive Assembly FM2-5360-000
              • ReproKev
                • 273
                It is definately only happening on cyan with a full color copy. I'll order the Drum drive assm and post back after install. Thanks.
                • ReproKev
                  • 273
                  Follow-up:
                  The drum drive assm took care of it! Thanks for the help.
                  BTW, anyone needing to do the same thing be advised - It's a good 2-3 hour service call.
                    • 16083
                    Follow-up:
                    i knew how long it took/ i did not want to scare you/
                    Great Fix !!!!!!!!!!!!!!!!!!!!!!!!!!
                    • SCREWTAPE
                      East Coast Imaging
                      • 3396
                      Nice fix.
                      Thanks for posting back.
                      • D_L_P
                        Self Employed
                        • Oct 2009
                        • 1196
                        Good stuff.
                        BTW what was the copy count on that copier? Just curious.
                        • SCREWTAPE
                          East Coast Imaging
                          • 3396
                          Originally posted by D_L_P
                          Good stuff.
                          Good question...
                          WHats uP DLP , you have been missing in action!
