image RUNNER 6000 series fixing web counter Error......
  • canonjh
    • 39
    Hi...
    1. COPIER>COUNTER>MISC>FIX-WEB 0000000
    fixing web counter up Error (0000000)
    2.COPIER>COUNTER>DRBL-1>FX-WEB.
    fixing web counter up normalcy (450000)
    fixing web counter Upload Not.....
    Please advise...
  • djbass
    • May 2008
    • 167
    Silly question.. but did you also clear the error: COPIER>FUNCTION>CLEAR>ERR
    Then power cycle the machine.
    No, I will not send you Manuals, Software or your own little repair Genie to fix all your problems for you.
    • canonjh
      • 39
      Silly question..
      Basic questions No Thanks..........
      COPIER>COUNTER>MISC>FIX-WEB Display 000000 fixing web counter Upload Not.....
      • SCREWTAPE
        East Coast Imaging
        • 3396
        I don't understand!
        Do you have a web error code E005?
        • canonjh
          • 39
          detects errors..
          COPIER>COUNTER>MISC>FIX-WEB Display C, Key Setting (000000)
          Main Power Off,on Copy run is used to reset , screen display counter zero status
          counter display 00000 Not Runring...
          • addoncopier
            • Feb 2010
            • 114
            I had it before, clear DRBL-1>FX-WEB, then COPIER>FUNCTION>CLEAR>ERR, if still the same you may need to refix your oil web properly, and check the senser, as well as thermistor. then fix it correctly, problem gone.
            • Brian8506
              • 1664
              I think you need to explain the problem you're having a little more clearly if you want intelligent help. You're description seems like text lingo.
              • canonjh
                • 39
                p-print misc fix-web counter up no
                • SCREWTAPE
                  East Coast Imaging
                  • 3396
                  I get you now!
                  Your web counter does not advance.
                  Upgrade System Software to version 60.04 or higher. Upgrade DCON to version 20.12 or higher.
                  This will resolve that issue. Sorry. I had ran into this a long time ago with this model.
                  • addoncopier
                    • Feb 2010
                    • 114
                    Normally, as a technicain i don't think you need any deep description. If you are not a technician better you call for services agent, or techinicain. Pay them and learn from them. XXX
