Need help to stop Canon C3220 C1 w/ Fiery NetBIOS broadcast!
  • tariqc
    The Fiery is attempting to broadcast over port 137 using the IP 10.255.255.2 . 137 is Netbios traffic so I disabled windows printing on the Fiery using the printer setup interface. I also disabled ports 137-139 in the security config, but I think that is for incoming connections. Neither fixed this. Does anyone know how to disable this broadcast? This doesn't seem like expected behavior since its not using the assigned IP address. I'm getting flooded with IP spoof alerts from my firewall.
  • SCREWTAPE
    East Coast Imaging
    • 3396
    Is the fiery picking this IP 10.255.255.2 on its own.
    Is this the IP address that's configured to the fiery?
    • tariqc
      Thanks for the reply. No the assigned IP is 172.xx.xx.xx
      According to this post
      http://www.copytechnet.com/forums/ca...tml#post109681
      the fiery and the printer have the IPs 10.255.255.1 and 10.255.255.2 and communicate their own network. I'm not sure why the 10.255.255.2 address is showing up on the LAN.
        • 16083
        what ver of C1 do u have -2.1/2.1.1/2.1.2 ???
        because there was a patch file released for Multicast/Broadcast for
        C3220/2620.
        Run the IPCONFIG command. Start/ Run=Type cmd and click OK. Then, type IPCONFIG /ALL. The details of your network adapters will be displayed. You can use this information to further troubleshoot errors on your network.
        • tariqc
          C3220/2620.
          its 2.1
          do you have a link to the patch? I can't seem to find it
            • 16083
            its 2.1
            check your PM
            • SCREWTAPE
              East Coast Imaging
              • 3396
              Are you sure you got this fiery connected properly.
              I remember seeing this scheme 10.255.255.1 and 10.255.255.2 on a sevice call with a H1. It had to do with troubleshooting communication between the imagepass and copier.
              You should have one device that communicates with your network, that would be the C1 ,via cat5e.(Ethernet cable). And the printer should be communicating with the fiery via crossover cable.
              The fiery and the printer should be communicating in a peer to peer protocol (IPs 10.255.255.1 and 10.255.255.2)
              As of matter of fact the copier should not be set up with a IP address, you should not even have that option from the machine when a fiery is mounted, you won't even see that option under system setting>network setting from the copier.
              Do you have a printer tab on the operators panel.
              You should see one called Printer, if not you fiery is not communicating correctly with the copier.
              • tariqc
                I believe it is setup correctly. I know I don't have the ports confused. Plus, everything prints and communicates fine. It just keeps trying to broadcast NetBIOS traffic over the LAN.
                Nope that setting is not there.
                Yes, I have a printer tab. I have to run setup to set the IP and other config.
                • SCREWTAPE
                  East Coast Imaging
                  • 3396
                  I just had to ask. Please do not be offended.
                  Starting from the basics is how I go about certain network matters.
                  Can you attach a configuration page.
                  • tariqc
                    Im not offended at all.
                    I appreciate you trying to help actually.
                    I'll see if I can get a config page tomorrow.
                    • SCREWTAPE
                      East Coast Imaging
                      • 3396
                      I have question. What OS are you running on the server.
