Couple thoughts. 1st, The scanner frame might have got bent in transport, its just natural to push it around with your hands on the scanner. I haven't seen it on a Canon before but have on a couple Ricohs. There is one front corner of the scanner that is unsupported, and we had to pull up on it and warp it a bit to get rid of some lines/weird shading just on the top half of the copy.
2nd, I'd still try swapping out the memory. Once we had delivered a copier and it was working beautifully. We put an ip address in and rebooted, boom wouldn't boot up. Long story short, we narrowed it down and just had to replace the memory sticks. Another time we had one that wouldn't print more then 50 without jamming, but only when printing PCL/PS. After swapping many, many parts, it is now working fine and has every original part except the memory. I remember on the way to OfficeMax thinking this is a waste of time, but we put it in and away she went.
Does this have the external parallel cable running from the scanner to the main controller? Try swapping/reseating that maybe.
