Hi,
I have ir8500 that has line about .400 apart on the lead edge of copies in the erase area. I just replaced the developer drive idler shaft (zebra strips from bad bearing and gear shaft) . I was also in the drum area and put in new blade. What could i have done . The lines are like .400 of inch apart. Could my erase lamp be messedup?? I am getting proper erase on lead and trail edges except for the lines. Other then that the copies are coming out perfect. Thanks for any help.
Later Pudgi300
Later Pudgi300
