Small start-up office was donated a Canon IR C3200. I have been asked to network as a printer to take burden off small HP printer and am having trouble getting the set-up. I have remote UI established; using a fixed IP; using an ethernet. Not sure what to try next. Is there a way to check if the machine has the optional Color Network Multi-PDL Printer Kit installed? Any suggestions are great appreciated!
Canon IR C3200 set up as printer
arborphot
check boot rom in service mode/ print out settings = need N Type with Fiery**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
