Irc 3100
thanks man..
i have another problem.. now i`m playing wit canon ir3570/4570 and i have major problem while i`m using duplex mode, it seem paper always stuck when the second copy applied. the paper will stuck inside drum unit after a few copies. i`m using 70gsm paper. it only stuck when i`m using A4 mode but not in A4r mode. any idea how could i solve this problem? should i change the paper weight or make any adjustment on the machine?
first= what are the Jam or Error codes ?
next= have u switched A4 to the A4R tray to check duplex from either tray
70gms is a little light for duplexing/20lb=80gms/24lb = 90gms better
many things contribute to Duplex Jamming on this series of printers/ Jame codes are important/ shows if it is a Delay Jam 01xx / or Stationary 02xx- screen also shows location area**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
mexuber
oh.. sorry i`m newbie, can you teach me how to starting a new message thread.. thanks a lot guys..Comment
follow procedure below> select tabs below as u go along
# Forum
# Technical Forums
# Copier Technical Discussion
# Canon
# Post New Thread
Forum>
select Link-Technical Forums/
then select-Copier Technical Discussion
next select> Canon
next select> Post New Thread
in Title> put in Machine Model #number.
then >write a small message explaining issue.
when finished /on bottom of message window >select >Submit New Thread
