Irc 3100
  • zak
    • May 2025
    Irc 3100
    Hi
    i have just replaced the drum and have not reset or iniated it by the service mode will that cause any problems, how do i get into the service mode.
    Many Thanks
  • teckat
    • 16083
    are u a tech ??
    • zak
      No
      • teckat
        • 16083
        Sorry but end users need to stay out of service modes/
        • zak
          i have technical computer skills and i repair PCs, i can manage the service mode as the instructions came with the new drum just need to access the service mode to do that thnx
          • teckat
            • 16083
            Additional Functions, 2 and 8 simultaneously, and then Additional Functions.
            wait until copier is ready then do >COPIER > FUNCTION > CLEAR > DRM-LIFE, highlight it and press "OK".
            good luck
            • Irish
              • 110
              A Thank you Would have been nice ...
              • teckat
                • 16083
                you don't seem do get a thank you from end users~~~~~~~~wait till their next post/problem~~~~~~~~~~~~~
                hey zak / wake up
                • zak
                  hey guys sorry ive been out most of the day i shall try your reply to my question tomorrow and like to thank you for your prompt reply
                  • mrfixit51
                    Lead Service Technician
                    • Oct 2008
                    • 1975
                    If Zak would have checked his private messages, he would have discovered that I had sent him a well defined procedure detailing the task...
                    • teckat
                      • 16083
                      Zak works to hard !!!!!!!!!!
                      Normally i would not out post a service mode procedure, because most end users mess things up, specially Print Shop owners, they will try to fix anything , i felt sorry for him/
                      • zak
                        a big thanks to all we're up n running .
                        Zak
                        • mexuber
                          ir 3100cn
                          i have a problem wit my machine, it appear E020-01a8&E20-02A1.. what should i do? i try replace ATR sensor, but it seen appear same error code.
                          • teckat
                            • 16083
                            Trouble Shooting error code E020-xx10, xx11, xx12, xx90, xx91, xx92, xx93, xxA0, xxA2, xxA8, xxA9.
                            There are several things that can cause E020's; ATR Sensor, Patch Image Read Sensor, weak Developer, DC Controller and Drum Unit.
                            Some simple trouble shooting can help you isolate the problem.
                            1. If possible make 10 color copies to force the ATR sensor to take readings. Then compare the SGNL reading for the color that is generating the error and additional colors in Service Mode; COPIER>DISPLAY>DENS>SGNL-Y/C/M with the Initialization setting in COPIER>ADJUST>DENS>SGNL-Y/C/M.
                            COPIER>DISPLAY>DENS>SGNL-Y/C/M arethe ATR Sensor readings of the Developer in its present condition and should be within +/- 100 of the Initialization settings.
                            COPIER>ADJUST>DENS>SGNL-Y/C/M arethe Initialization settings that the copier maintains and are usually between 400 and 650
                            2. If the Initialization setting is outside these numbers the Developer Unit will need to be replaced.
                            When replacing the Developer Unit, make sure to execute:
                            - COPIER>FUNCTION>INSTALL>STIR-Y/C/M
                            - COPIER>FUNCTION>INSTALL>INIT-Y/C/M
                            - COPIER>FUNCTION>INSTALL>SPLY-H-Y/C/M
                            After Initializing the Developer Units print a P-print and keep with the copier.
                            -COPIER>FUNCTION>MISC-P>P-PRINT
                            3. If the ATR Sensor reading is over +/-100 of the Initialization setting; the ATR Sensor, Patch Image Read Sensor, Drum Unit and DC Controller are suspect.
                            Check the status of the Drum Unit under COPIER>DISPLAY>MISC>DRUM-LIFE. The Patch Image Read Sensor looks at a patch of toner that is generated on the drum for each color and determines the amount of toner that is in the patch by the amount of reflected light. If the drum is not creating the patch correctly, the patch reading will be affected. Replace the Drum Unit if it is close to or over 100% of its rated life.
                            If the Drum Unit is not close to or over its rated life, replace the ATR Sensor and Patch Image Read Sensor. If the error continues replace the DC Controller.
                            5. If over toning continues to occur the Toner Supply Clutch (CL7) may be sticking and need to be replaced.
                            ATR Sensor Assembly PN: FM2-0096-000
                            Patch Image Read Sensor PN: FH7-7629-020
                            Developer Assembly (Black) PN: FM2-1751-000
                            Developer Assembly (Yellow) PN: FM2-1752-000
                            Developer Assembly (Magenta) PN: FM2-1753-000
                            Developer Assembly (Cyan) PN: FM2-1754-000
                            GPR-13 Drum Unit PN: 8644A004AB
                            DC Controller PCB Assembly (IRC3100) PN: FG3-3846-030
                            DC Controller PCB Assembly (IRC3170) PN: FG3-3847-000
                            Toner Supply Clutch (CL7) PN: FH6-5005-020
                            *** The ATR Sensor and Patch Image Read Sensor both determine toner density. Depending on the density readings the copier will or will not add toner. Check the status of the Drum Unit under COPIER>DISPLAY>MISC>DRUM-LIFE. The Patch Image Read Sensor looks at a patch of toner that is generated on the drum for each color and determines the amount of toner that is in the patch by the amount of reflected light. If the drum is not creating the patch correctly, the patch reading will be affected.
                            Replace the Drum Unit if it is 80% of its rated life or higher.
                            or
                            perform the following field remedy to adjust the toner/developer ratio (T/D ratio) inside the developing assembly close to the normal level by supplying toner for the specified developing assembly.
                            1. Turn the control panel switch OFF > turn the main power switch OFF/ON.
                            2. Go in Service mode > COPIER > Function > INSTALL > SPLY-H-"X" ("X" means the problematic color: "1" is Yellow, "2" is Magenta, and "3" is Cyan.) > Highlight OK.
                            3. If the symptom still occurs, replace the developing assembly with a new one.
                            Note: Never change the setting values for [SGNL-Y] through [REF-D] under [Service mode > COPIER > Adjust > DENS]. Also never perform the following service mode item when the error code has been displayed; [Service mode > COPIER > Function > INSTALL > INIT].
                            • mexuber
                              ir 3570/4570
                              thanks man..
                              i have another problem.. now i`m playing wit canon ir3570/4570 and i have major problem while i`m using duplex mode, it seem paper always stuck when the second copy applied. the paper will stuck inside drum unit after a few copies. i`m using 70gsm paper. it only stuck when i`m using A4 mode but not in A4r mode. any idea how could i solve this problem? should i change the paper weight or make any adjustment on the machine?
