Sorry, I wasnt clear-the one machne that prints promptly is a problem. It basically ignores the secure print and outputs like a regular print job.
The cust has 5 ir 5050-same drivers. The other machines secure print. Thanks!
Go to select file from your application
Select properties from the printing dialogue window
In that output method select secured print.
Click on the secured print settings button and enter a password.
Now this is where things changed up a bit,
Before we use to go to system monitor now we must go to the print job tab, hit the right arrow on the control panel screen, select type and choose secure print.
Highlight that secure print job that's located at the bottom and enter the password that you gave that printed job. Hope this helps.
