SST connection via network
  • Canondude
    • May 2025
    I'm trying to connect to my IR105 via network but I keep getting error code 147.
    Seems its can't connect to the copier. Any idea?
    • 16083
    Originally posted by Canondude
    1. Start up the laptop
    2. Check to be sure that your laptop/network settings as follows:
    IP address: 172.16.1.10
    Subnet mask: 255.255.255.0
    Default Gateway: none
    1. Turn off the machine’s power switch.
    2. Connect the machine and the PC with a cross cable.
    3. While holding down the 2 and 8 keys of the keypad on the copier’s control panel at the same time, turn on the main power switch (so that the copier will start in download mode within safe mode).
    Start up the SST.
    • Canondude
      Thanks teckat, but it seems the copier is not responding. Any particular reason for this?
      • bnmand
        • Sep 2008
        • 383
        I don't believe the 105 supports Fixed-IP mode in download mode. The 105+ does.
        Check the Device Specific Notes section at the end of the SST manual.
        • SCREWTAPE
          East Coast Imaging
          • 3396
          Try using the USB parallel cable. You might need the canon one if your laptop does not have a parallel port.
          Also, what service support tool are you using?
          • Canondude
            I'm using 4.22. I might just have to take my desktop to the copier...
            • davidj7
              • 1107
              i had a similar issue have to set ecp for the port in bios. I was using parallel port
                • 16083
                A code 147 = TCP/IP connection error fail with the Service Support Tool when flashing > you should immediately ping the host machine. If you get a reply, and still get the 147 error, try setting IMG-CONT to 0 in service mode: Copier/Option/Int-Face/Img-Cont. Then set the machine up again, in safe mode try flashing again. Don't forget to reset Img-Cont back to 3 after flashing the machine.
                SST FOR IR 105:
                CROSSOVER CABLE
                NORMAL POWER ON MODE
                [Customers IP: 192.19.1.20 - Laptop: 192.19.1.21]
                Connect in reference to customers IP Address
                "CANNOT" PERFORM HD-FORMAT
                CROSSOVER CABLE
                SAFE MODE
                [HOLD DOWN 2 & 8, POWER "ON" Machine]
                PERFORMING HD-FORMAT
                USB TO PARALLEL [FY9-4154-000]
                [Nethawk Driver Needed]
                SERVICE MODE
                [SERVICE MODE>COPIER>FUNCTION>SYSTEM]
                SERVICE MODE
                [* 2 & 8 *]
                PARALLEL TO PARALLEL
                [Low Speed with Win XP/ Win 2000]
                SERVICE MODE
                • Canondude
                  So I carried over my desktop and tried to connect via parallel to parallel port but came up with error code 100 (Opening of the communication port has failed).
                  ECP was set in BIOS. Please help?
                    • 16083
                    your post message has SST via network ???
                    if you are using the SST to install ir105 Firmware/ u should have only one ver. of SST on the PC/or Laptop !!!!!!
                    if u are setting up up a network/ u do not need the SST !!!
                    please explain what are u trying to do ?????
                    • Canondude
                      Maybe I wasn't clear. I'm trying to format and install the firmware. As I tried to connect to the copier via network - it didn't work. So I took the alternate way, using parallel ports.
                        • 16083
                        "CANNOT" PERFORM HD-FORMAT with PARALLEL TO PARALLEL
                        on ir105
                        When installing a new blank Canon Service Replacement HDD you must utilize Mode C on ir105 to format the
                        entire HDD.
                        Ok ! - so u have a new HDD in the ir105 ?/ if not u can format the old HDD in the service mode /and u need to re-install the ir105 Firmware ? / /
                        u have the SST installed on your PC- correct & not on a Laptop- ?
                        On v86.02 for ir105-The ALL & ALL_HDF files have not been created and added to the System Software due to issues during
                        testing of the firmware.Please flash the software using the “Single” link.
                        System Software v86.02
                        Boot ROM v26.44
                        Language v86.02
                        RUI v83.01
                        DC-CON v10.06** [iR105]
                        R-CON [105+/9070/105/8500] v10.01**
                        HD Format v00.11
                        DADF-J1 [105+/9070/105/8500] v7.01**
                        Finisher-K1/K2 [iR8500] v4.03/v4.01**
                        Finisher-K1N/K2N v24.01/v22.01**
                        Saddle Finisher-K3/ K3N v6.01**
                        Booklet Trimmer-A1 v6.01**
                        ** Not included with this System Software bundle
                        When upgrading the imageRUNNER 105/ 8500/ 7200/ 85 from v85.02 to v86.02, the Language
                        must be updated to v86.02.
