iR2570 C
  • songela
    • Mar 2008
    • 216
    iR2570 C
    Hey, has anyone come across this problem? please come for help!
    Error code E000020-0081 is being displayed so frequently. Of course I know which sensor to clean,
    the P-SENS-P, but it takes quite few copies (about 200) for the toner dust to accumulate on it and the error is back again. So please, what can the cause and what is you suggested remedy?
    Regards!
  • montana
    • Aug 2008
    • 393
    hi...i suggest you to check if ther is any toner leakage or abnormal recycling or damaged antispill blades
    thanks...
    • mrfixit51
      Lead Service Technician
      • 1975
      Dirty sensors in these copiers fall into two category's, poor maintenance, or drum/developer assemblies that have gone too far beyond life. If the drums or developers are beyond 100% of life, change them, and vacuum all around the turret area.
      • candoo
        • Nov 2008
        • 14
        You could try removing the transfer belt and cleaning all the drive rollers in the ITB assy. If the belt is slipping you will get this error. Also, ensure all earth tabs are making good contact, especially the one on the front frame side of the registration roller as this will cause this code. If the macine is getting dirty from toner spray you may have to replace the colour dev units, they have a life of only 30000 prints instead of the durable counter value (usually 500000).
          • 16083
          Regards!
          machine checks the patch image read sensor for soiling. While initial multiple rotation is under way, the machine measures the light from the surface of the drum without depositing any toner on it (drum background measurement); it will assume that the window is soiled if the measurement is lower than a specified level (COPIER>DISPLAY>DENS>P-SENS-P> optimum range: 400~600), thus indicating an error code (E020-0081) and stopping its operation.
          simple fix/ just replace the drums/probably are old if error returns this fast/u can also replace the Image Patch Sensor if old
          • zoraldinho
            teacher-guide-expert-guru
            • Mar 2008
            • 5007
            Regards!
            There is no starter in developers.you must change them.
            • zoraldinho
              • Mar 2008
              • 5007
              This machine have only one drum.
                • 16083
                typo error /I meant Drum= poor & old drum surface will cause an overtone of your developers
                • songela
                  • Mar 2008
                  • 216
                  Thank you all for useful suggestions, I will put them to use and report back any success.
                  Regards!
                  • mjarbar
                    Also check the customer isn't doing more than 1 in 8 pages colour as this will cause the code to appear more regualy than normal (but then what is normal for these machines apart from broken!!!).
                    For a colour page the drum will rotate 4 times instead of the 1 for black causing the drum to wear far quicker that normal.
                      If the customers doing a lot of colour, Canon have estimated a drum life of around 17.5k..
                        • 16083
                        Remember that's at 6% to 8% coverage l:/
                        • steveyg68
                          all the time
                          I work on these machines daily, and yep they are a pain, before stripping it all out, check if one of the devs have dumped itself all over. If not, has it in the past and not been cleaned up correctly, remove the drum and check the back of the drum, if its covered in toner , look down where the drum was at the base of the machine, is there toner there, or at the back of the turret, which again you can see through and down where the drum normally sits, another tell sign, the laser cleaning rod , (blue thingy) is the got loads of toner on it. If so then the loose toner is being flicked up by the turret, and im affraid 3 hours strip vac out and clean to stop it. Devs can leak a lot especially the yellow and cyan.
                          The second if no excess toner is present, the patch sensor although they are a sealed unit they can get toner in it behind the lense, ( i have had a few like this) if nothing else works and its clean, change the patch sensor, The enviroment sensor can fool the system too if this is dirty, why as its totally different but again experience has shown me that these m/c are bitches (it sits next to the patch sensor) If you need more details on problems on 3100 3170 range just message me. Had a lot of time on these suckers.
                          steve
                          • Canuck
                            Tech Specialist
                            • 1713
                            When cleaning the patch reading sensor,clean the shutter assembly that opens and closes over it also and never use a dry rag to wipe the sensor window...like on clcs this will create static on them and toner will attract to them. Use a super wrung out piece of cloth. The machine as stated looks at the clean drum surface before generating patches. Having a roll for primary charging beats the heck out of the drum surface...like said earlier 4 separate images for full color. So if the drum is not all nice and shiny it doesnt reflect anything back,plus if it is not cleaning properly. Yeah, the tool of choice on these pigs is the vacuum. You can notice on used drum assemblies the cover for the primary roll is always filthy. Toner chugs out from that area right onto the patch sensor. Put a new drum in it,then clean the patch reader assembly
                            • jacky
                              • Jun 2009
                              • 61
                              Bro,do you try and check the photo sensor? faced same issue by replaced the sensor.
