C3200 Transfer Belt
  • jo2270
    • 14
    C3200 Transfer Belt
    Hi I am being sent out to replace a transfer belt on an IR C3200. I have never worked on this model before and am not even sure where the transfer belt is. Would anyone have the service manual or replacement instructions for the transfer belt that they would be willing to share? Thanks in advance for you help.
  • welshman
    Technical Support Manager
    • Oct 2007
    • 91
    Its Easy
    Right hand side of machine pull out tray
    above this is a cover one screw remove screw and cover
    open front door rack down the handle
    right hand side slide out the transfer belt unit
    replace belt let you figure that one out not rocket science
    re assemble reverse of removal
    have fun or get in a trainded tech to do this job
    • SCREWTAPE
      East Coast Imaging
      • 3396
      Dude, the first steps are simple.
      Replacing the belt for someone who has never done it before... Challenging.
      Good luck.
      • smiley
        • Aug 2008
        • 616
        jo2270 send me your email ad. i will send you the manual its soo easy if you used to replace it, it can be done with in 2 minutes.but if your a newby it can takes 1 hour and there is a posibilities that you can ruin your new belt.
        there is no glory without sacrifice
        • teckat
          • 16083
          Better bring two belts/ just in case
          what a brilliant manager to sent u out to do this without some hands on knowledge/ I also recommend that when u replace an ITB belt >replace the ITB cleaner blade / it's a good maintenance practice
          • anothertech
            • 1762
            And don't forget to clean the drive roller while you have it apart.
            Run Auto Gradation Quick adjust when you get it back together.
            • jo2270
              • 14
              Thank you. I have sent you my e-mail address.
              • jo2270
                • 14
                I agree with all of you
                I have told my manager that I am not the person for the job. I am a printer tech. Unfortunately, I am the only one cleared to go to this site, so when a copier breaks, I get sent out, I have no choice in the matter.
                • teckat
                  • 16083
                  how about the company u work for spending some money and provide training/ anyone in this forum who says this machine is easy to work on > without some hands on knowledge , is a Liar. it can turn into a mess. those Canon manual illustrations have never been helpful to me ,and I am trained on over 30 Canon products.
                  send me your companies e mail, I want to say something to them.
