Canon 5070 Light prints
  • imageworks
    • Aug 2025
    meter at 260K real light faint prints this is a new model to me help appreciated... Also is there a trick to releasing drum carriage assembly?
  • SCREWTAPE
    East Coast Imaging
    • 3396
    For starters you can check your transfer separation corona ass'y.
    There's really no trick to pulling out the Ap-kit, just the right way.
    Do you have somewhat knowledge of this machine??
    • imageworks
      canon
      yes somewhat ! It kicked my butt today....should i restring the corona assembly evrything appears fine with it but ? attempted to slide drum unit out but no success with all 40 screws i took out
      • SCREWTAPE
        East Coast Imaging
        • 3396
        Just replace the transfer sep corona.
        Its like four screws to pull out the drum.
        There one that holds the drum and three sliver screws.
        You must take out the developing assy first which is one screw and remove the plate then pull it out.
        So the total is like five screws.
        What about potential control, are you familiar with this function?
        • imageworks
          canon
          sounds easy enuff Canon not really touched much so its a slight bit foreign to me but i think i can figure out potential not at all familiar with. you have a pdf manual you could email would be awsome. imageworks@rocketmail.com I can figure out from there. Man I really appreciate your help
          • D_L_P
            Self Employed
            • Oct 2009
            • 1196
            We have had a couple of these with very faint copies. The VD and VL were good and drum pot was 680ish. It seemed to be related to the developer. We pulled out the developer and vacuumed it off, cleaned all the contacts and wiped the developer cyc clean with a dry towel. Doing a Dc-Con clear brought it back somewhat, but we had to replace the dev cyc on the other one. Service mode-> copier-> function -> clear-> DC-Con.
            Good call about taking out the developer 1st and the one big screw that holds the drum.
            • Canuck
              Tech Specialist
              • 1713
              Turn off potential control in service mode and see if it makes a difference. I have seen the potential control harness wires get squished. No errors? Try reseating the laser assembly...this was a known problem on this family of machines...Canon modified the mounting brqackets actually. Also make sure that the primary duct cover is not broken....the actuator for the laser shutter is part of the assembly. I know,..on this machine laser erases background so unopen shutter should cause dark copies but i have seen cases where it interferes just enough to mess up VD and VL during potential control. CYA...rewire all the coronas as a start...only takes 15 min.
