Blank Copy
  • ajeet
    Blank Copy
    Hi everyone
    I m having a problem in IR400 machine.Copy is totally blank
    I checked each & everything related to this.
    KIndly Suggest me what should i do
    Thks
  • D_L_P
    Self Employed
    • Oct 2009
    • 1196
    Did you check the blue developer handle? Sometimes it breaks and will overextend causing a gap between the dev unit and drum. You can replace it if it's cracked/broken or if its just worn through the plastic I've found if you screw in a smaller screw in that hole that will fix it.
      • 23008
      Yeah, the developer handle breaking off it's endstop is very common. =^..^=
        • 16083
        Originally posted by ajeet
        Hi everyone
        Thks
        Blank copies will be generated if the Developer Drive Clutch CL4 is defective. To determine if the drive clutch is the problem, remove the developer assembly and check to see if a portion of the cylinder is missing toner. If toner is missing and the developer cylinder is visible, check the operation of CL4.
        • Canuck
          Tech Specialist
          • 1713
          Yeah check positioning of dev handle...also check the transfer roll is mounted properly...they like to come out of place. Do you have image on drum?
