Canon Driver Configuration Tool (CDCT)
  • teckat
    • 16083
  • TJBoy
    • 22
    Help with the Canon Driver Configuration Tool
    Hi,
    I need to modify the driver output method from the default seeting "Print" to "Store", how do I do that using the Canon Driver Configuration Tool???
    This is a Canon iR C3200
    Sorry if this is a very basic question but I have tried and so far I have not been successful.
    Thanks for any advice.
    • teckat
      • 16083
      Originally posted by TJBoy
      Hi,
      What exactly are u trying to do ????? modify what driver ??
      Installation:
      1. Double-Click the [Setup.exe] file on the installation disk to start the setup Wizard.
      2. Read the software license agreement.
      3. Specify the folder where you want to install the utility.
      4. Click [Next] in the [Confirm Installation] screen.
      5. Click [Close] when the screen indicating the installation has finished.
      Uninstalling:
      The Canon Driver Configuration Tool can be un-installed using Windows Add/Remove Programs from the
      Control Panel.
      • Installed Drivers continue to operate as usual.
      Sample Configurations:
      • Force Black & White Only Settings:
      1. Click on [Settings] box on the “Dialog Box Elements Display Settings” option
      2. Under the [Quality] tab disable all options by clicking on [Disable All] button then [Enable]
      “Black and White” in the drop down next to the “Black and White” option.
      3. Then Click on [OK]
      • Force Duplex Only Settings:
      2. Under the [Finishing] tab disable all options by clicking on [Disable All] button then [Enable]
      “2-sided Printing” in the drop down next to the “2-sided Printing” option.
      • Force Secure Print Only Settings:
      2. Under the [Common] tab disable all options by clicking on [Disable All] button then [Enable]
      “Secured Print” in the drop down next to the “Secured Print” option.
      • Force Printing to Mailbox Only Settings:
      “Store” in the drop down next to the “Store” option.
      When installing a configured driver, if a message that the driver has not passed the Windows
      Logo test or the driver set does not contain a signature is displayed, continue the installation.
      • Only standard driver sets produced by Canon can be used as base for configuration.
      Configured drivers sets cannot be used as base.
      • If you are using the 32-bit version of this utility, obtain a 32-bit driver set. If you are using the
      64-bit version of this utility, obtain a 64-bit driver set.
      • You cannot configure 64-bit drivers on 32-bit operating systems or 32-bit drivers on 64-bit
      operating systems.
      • The [Dialog Box Elements Display Settings] dialog box displays all of the items, selections, and
      buttons whose display modes can be modified using this utility, regardless of printer type.
      Items, selections, and buttons that are not supported by printers that have been or are to be
      configured are not actually displayed even if their display mode is set to [Enabled].
      • You cannot configure the Online Help, so Help topics that are displayed when you click the
      configured driver [Help] are the same as those displayed in the standard driver online help. As
      a result, the Help topics for items that you have set to [Disabled] or [Hidden] remain available
      to users.
      • To update a configured driver, you must uninstall the existing configured driver, reconfigure a
      new driver based on its standard driver set, and install the new driver.
      • TJBoy
        • 22
        Tried that but...
        Thanks for the info teckat,
        I followed your directions to force printing to mailbox but when I installed the new custom driver the output method appears grayed out with the "Print" option selected instead of Store...
        I'm using the PCL5e-c_v8.62_win2k-xp-2008-vista_INF.exe base driver if that helps.
        Just did the following:
        • D_L_P
          Self Employed
          • Oct 2009
          • 1196
          After you set it to store is there a place to tell it which mailbox you want?
          • TJBoy
            • 22
            and [Enable] next to the Secured Print/Store Details and Store Details
            So basically the same as teckat instructions, just enabled 2 more rows.
            Thanks to all for your help, this installation was a success.
            • teckat
              • 16083
              • matthanielcm
                Where to find?
                My work has been trying to find this program for a few days now. Where can we find this program? All we can find is the Japanese version. Thanks.
                • zaza
                  MECANOGRAPHE
                  • Mar 2008
                  • 1095
                  BEST TECHNICIAN . NICE PEOPLE .
                  • jazzert100
                    • 5
                    Can someone post a link to this software?
                    J
                    • xman
                      • Aug 2010
                      • 48
                      Re: Canon Driver Configuration Tool (CDCT)
                      Hi there,
                      Can someone please post a link to download the latest version of the Canon Driver Configuration Tool
                      Thank you
                      • ADV COPIER
                        Pemain
                        • Nov 2022
                        • 257
                        configure for what ?
                        Let's Drink our Coffee
                        WhatsApp +62895325228383
                        • xman
                          • Aug 2010
                          • 48
                          I have a canon C5840i that I want to force secure print.
                          Please assist with instructions and driver config tool to achieve this.
                          Thank you again
