IR 2870
  • jose1020
    • 41
    IR 2870
    Error Code E00064-0003 ?
  • SCREWTAPE
    East Coast Imaging
    • 3396
    That's your HVT PCB.
    That's a misson to get out.
    How were your copies, Full black?
    • teckat
      • 16083
      just to add on>
      E064 code with a 0003 sub code can occur if Toner gets on the Developing Bias Tab. If the Toner is getting on the Developing Bias Tab you should check the seal on top of the Developer.
      • jose1020
        • 41
        Yea is full black
        • teckat
          • 16083
          Yea is full black
          solid black with no white edges ?
          • jose1020
            • 41
            Yeap solid
            • jose1020
              • 41
              I'm sorry is not black is white copies full white copies
              • teckat
                • 16083
                U now mean blank no images
                Check to make sure the developing cylinder is turning
                • jose1020
                  • 41
                  Yes the developer is turning there's not image on the drum, I replaced a couple of boards and it's still printing blank copies. By tha way is thi HVT PCB tha high voltage power supply?
                  • teckat
                    • 16083
                    what about Laser Shutter operation
                    • SCREWTAPE
                      East Coast Imaging
                      • 3396
                      Wouldn't you think he get a E100 though?
                      • jose1020
                        • 41
                        i check the shutter and that's fine
                        • SCREWTAPE
                          East Coast Imaging
                          • 3396
                          If there was a E64, 9 times out of ten it gonna be a bad HVT.
                          You can also check the drum tabs that make contact with the HVT.
                          Have you tried a different drum?
                          • jose1020
                            • 41
                            Yes i tried different drum. Where is the HVT located?
                            • SCREWTAPE
                              East Coast Imaging
                              • 3396
                              Its by the right side door, the inside rear. You have to take out mostly everything to get to it.
