conon ir1018j download standby
  • jubest
    • Jul 2025
    what can i do
  • hemai2005
    Professional Print
    • 108
    your machine needed firmware
    or replace DDR
    any choice will solve the problem
    take care
    sigpic
    Learned a lot will become an expert
    • teckat
      • 16083
      Originally posted by jubest
      what can i do
      what are u trying to do ??
      • DAG COPIERS & COMPUTERS
        • Oct 2010
        • 860
        Re: conon ir1018j download standby
        Trying to flash an ir1018j with firmware version 68.01.01 but seem its not compatible, since the machine tells me 'wrong firmware version, use firmware for ir 1018j'. JUst want to know if the firmwares for iR1018, 1020, 1022, 1035 models are NOT compatible with iR1018j.
        Thank you.
        • teckat
          • 16083
          Thank you.
          do u see "j" firmware in SST
          <Points to note>
          (1) If upgrading from an older version to v60.03 (or later), the BOOT area is increased.
          At the same time, the SYSTEM writing start address (FLASH-ROM) is changed.
          The SYSTEM writing start address is included in the BOOT v60.03 and later, so after BOOT has completed downloading, turn OFF and ON the power, so that the new SYSTEM writing start address is reflected.
          Upgrade procedures
          <Without options>
          1. Overwrite BOOT.
          2. Check that "OK" appears on the touch panel display. Then, turn OFF and ON the power manually.
          (Download mode starts.)
          3. Overwrite SYSTEM.
          <With OPT16MB>
          1. Overwrite BOOT.
          3. Overwrite OPT16.
          4. Check that "OK" appears on the touch panel display. Then, turn OFF and ON the power manually.
          5. Overwrite SYSTEM.
          <With OPT32MB>
          1. Overwrite BOOT.
          2. Check that "OK" appears on the touch panel display. Then, turn off and on the power manually.
          3. Overwrite OPT32.
          4. Check that "OK" appears on the touch panel display. Then, turn off and on the power manually.
            • Oct 2010
            • 860
            No Sir, I only see the iR1023 displayed, nothing else.
            • teckat
              • 16083
              U will need to contact
              a Canon Service Company > if possible
              • laitang
                • Nov 2012
                • 627
                Perhap you need v.80.04
