I have a ir5000 and it has been running great for years, but lately it has been jamming in the fuser. I tried running card stock through the bypass and it works just fine. I tried running plain paper through the bypass and it jams every time. Any help would be appreciated.
Canon ir5000 paper keeps jamming in the fuser
so is it jamming in the bypass of the fuser?
If you are having plain paper jams in the fuser I would look at your delivery rollers, LFR and bearings, UFR and bushings along with the fixing web.
If it is jamming in the bypass you need to look at that seperation roller and feed roller.Accidents don't just happen. They must be carelessly planned. -
A simple thing I look at is if the paper is jaming before the fuser - check/clean the transfer/separation assembly (not to mention when was the last time the corona wires were restrung). Heavy stock is - heavy so it lays down easier. Standard paper needs to be "pulled" down or it misses the fuser "slot". Just a SWAG though.Comment
Are you a tech or end user?
Are you running the heavy and plain paper in the same direction?
Do you have any jam codes?
You might have 2 issues, one with the bypass and another with the fuser. The rollers in the bypass might need replacing.
Anyway, besides replacing the fuser rollers I've only had one other somewhat common cause of jams. The one-way gear on the fuser exit (delivery) roller, part #FS7-0658-000.Comment
In addition to the one-way DIP mentioned, There is a gear that drives the fuser and trans belts, The "Little Monster" is about the size quarter If the gear is white it is the old style, the failure is deceptive, the gear does not round off but gets very pointy and can be easily overlooked. Canon released a new black gear. I find it hard to believe that the original gear is still working/being used but if an "INDE" has been servicing the box it may been replaced with the old style. If you have not already ruled out that option it may be worth a look. Let me know I will get you the part # if needed.
Peace.Comment
WHOOPS! I gave you the wrong part #, I was just looking for a different part and happen to see that gear in my case. The correct part # is FS7-0664-000.
I was looking at item #100 but for some reason gave you item #110, I guess I had a brain fart.
These gears are on the back of the fixing frame (drawer), pull it out and you can see them. The gear I gave you the part # is on the left most roller with gray tires. You can check it by holding the gear and spin the roller, it should spin freely one way and hold (no slipping) the other way.
The monster gear is the bigger of 2 gears with a skinny belt that drives the transfer bed. The bed are those super wide transport belts between the fuser and transfer corona unit. Like Goose said old is white, new is black.Comment
02Of = 02-stationary, OF-claw jam (PS4) So basically the paper is sticking to the Upper roller and crashing into the sep claws.
Have you replaced the fuser rollers? Always put new claws in with a new roller, old ones can ruin the new roller.
99% of the time replacing the UFR, claws, bushings and bearings fixes that. 1 time I recall a newer tech accidentially set the nip extremely high. He thought those screws were for taking the fuser out.Comment
Do you know where I can get those parts at a reasonable price? Maybe Katun? also the UFR is smooth and the LFR has lines horizontal lines on it.Comment
If you've never done it before I'd recommend getting a manual. Katun is probably your best bet, Precision Roller is another.
Here are the parts you probably will need:
1 FB4-3690-000 UFR
2 FB5-3613-000 bushings
2 XG9-0421-000 UFR Bearings
1 FB5-3619-000 LFR
2 XG9-0383-000 LFR bearings
6 FB5-3625-000 UFR claws
UFR should be smooth, new ones will look glossy old ones will be dull. LFR should be smooth and glossy, old ones get wrinkles and/or flat spots.Comment
http://www.precisionroller.com/fuser.../products.html**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
Thanks Guys, I ordered the parts, they should be in any day now. I will let you know how it goes.
BTW does any of you guys have any beer I could borrow?Comment
