It prints 3-4 A4 and looks like it stops and starts again.Maybe it prints 20-30 duplexed papers in a minute and is to much slower than Toshiba e-studio 550(55 ppm).
make sure u have at least v12.08 / it address that issue of process speed for two-sided printing.
is it while using DADF for scans or thru Network operations ???
It happens when i print from computer using network connections.
My IR 105 has also usb printing options!
Maybe is better if i use that port and not network controller?
I'd give that a try before I'd mess with usb, which is slower. There are several things to try for printing slow, but since there is a firmware update addressing specifically duplex I'd try that 1st.
Are you a tech or end user?
Does this have the Fiery controller or the built in Canon controller? We had one it turned out to be the Fiery was not compatible with their DOS programs.
For slow printing in general, not just duplex.
At Copier:
Turn on print after completing RIP
Turn off spooler
At Copmuter:
Try different driver
Change from immediate to Start printing after last page is spooled
Try Print directly to printer
Make true LPR port or switch to RAW port 9100 or turn off LPR byte counting
Don't use print server, print local
There's more but I think the newer version is your best bet.
My IR 105+ has a integrated controller and not a Fiery like my CLC3200.
I am using PCL6 drivers and not PS drivers.
Now i will install latest PS drivers to see what happens !!!!
I tried to use PS driver and its terribly slow.
I see only "Waiting to print" on monitor and a printed page ones in a minute.
did u check your 105+ firmware version like I posted earlier ????
v12.08/ ****addresses Modification to correct the
processing speed on the
imageRUNNER 105+/9070 when
Booklet and 2-Sided print settings are
specified
****When Booklet and 2-Sided print settings are specified, copy processing
speed of imageRUNNER 105+/9070 are slower than imageRUNNER
105/8500. This speed is improved (to be the same speed as
imageRUNNER 105/8500).
