cant scan from a z40 to canon clc 1150
  • plmnbvcxz
    • Aug 2025
    cant scan from a z40 to canon clc 1150 it say no twain i did all the ip and the drivers it was working ok for the last year help me . thanx
  • teckat
    • 16083
    If you scan any job from the copier when the ColorPASS is turned off, scanning is not
    performed even though you turn on the ColorPASS subsequently, and Fiery Scan may not
    be able to connect to the ColorPASS after the ColorPASS is restarted. If this happens,
    reboot the ColorPASS.
    try checking firewall settings / & disable -or :
    If u recently upgraded Windows components on a PC, specifically upgrading to Internet Explorer version 7/8 , the Fiery Scan utility may not function correctly when trying to scan into a TWAIN application.
    U can restore the Z Series ColorPASS to Factory Defaults without Reloading System Software
    First print out a Configuration Page:
    1) At the Control Panel, Press the Menu button to access the Functions menu.
    2) Choose Print Pages.
    3) Select Configuration.
    1) Make sure the ColorPASS is at Idle.
    2) Press the Menu button and choose Shut Down.
    3) Choose Reboot System.
    4) Immediately press the fourth line button (from the top down) and hold it down until the diagnostics have finished.
    5) Choose Restore Backup.
    • D_L_P
      Self Employed
      • Oct 2009
      • 1196
      Z40? Wow isn't that the old dark gray one that mounted on the side and I believe had WinNT?
      Have there been any changes with your setup recently?
      • plmnbvcxz
        yaaaa it to work the problem is that i gave it a deferent name in the set up
        • plmnbvcxz
          thanks for all the help i also have a z400 and a z800 to for my other to printer 1150 1180 1140
          • teckat
            • 16083
            good find/
