iR4570 DCON Firmware
  • Dedy.P
    • 67
    Hi guys, anyone got iR4570 DCON Firmware, i really needed for my job, i only had iR2270 & 3570 DCON Firmware, and if i download it to iR4570, its only appears COPY & MAILBOX, if i download it to iR3570 its appear COPY, SEND, MAILBOX, & SCAN.
  • davidj7
    • 1107
    whats your e-mail
    • SCREWTAPE
      East Coast Imaging
      • 3396
      DCON firmware has nothing to do with send or scan.
      Dcon is for the Dc controller and this PCB controls, laser, motors, clutches, ETC.
      Perhaps your not quite familiar with Canon firmware.
      • Dedy.P
        • 67
        Originally posted by davidj7
        whats your e-mail
        Dedy.purnawan@gmail.com
        Thanks.
        • Dedy.P
          • 67
          So what should i do then Screwtape?
          to make it all appears
          • Dedy.P
            • 67
            recently i had try change the copier type (iR4570 to 3570) and the copier become normal (appear copy,send,mailbox & scan)
            And when i turn it back the copier to iR4570 it's only appear copy ??
              • 16083
              mageRUNNER 2270/4570/3570/2870= all have the same Firmware / System Software v40.03
              DCon is v30.02 for 3570/4570/2270/2879= DUH'
              if u are using a G3 FAX v79.01 = make sure u update the settings for it
              ******READ
              1. Canon USA, Inc. recommends using the latest version, currently v4.04Eq.
              2. When the version of the System Software for the imageRUNNER 2230/ 2830/ 3530 ROM and HDD models is
              upgraded, it is upgraded by means of overwriting. All set values for user mode and service mode are retained. As
              a result, no items are initialized.
              3. For the imageRUNNER 2270/ 2870/ 3570/ 4570, due to interface modifications related to changes made with the
              new features added to the System Software, the following items will not be carried over when upgrading:
              a. Copy: Mode Memory (Special Features), Recall (Special Features), Standard Settings (Additional
              Functions>Copy Settings)
              b. Inbox: Mode Memory (Special Features), Standard Settings (Additional Functions>Mail Box Settings)
              c. Universal Send: Recall (Favorite Buttons can be carried over by exporting them prior to upgrading and
              importing after the upgrade – RUI>Add. Func.>Import/Export>Forwarding Settings)
              d. Log: Status and Log (System Monitor)
              e. Additional Functions>System Settings>Device Information Delivery Settings>Register Destinations:
              Destination address list will need to be recreated
              f. Additional Functions>System Settings>Device Information Delivery Settings>Deliver/Receive Log: This
              will be erased and also renamed to “Communication Log”
              4. The version of the PreInstallApps included on this System Software CD contains versions that are newer than
              those previously provided for the imageRUNNER 2270/2870/3570/4570. If a copier is upgraded to v34.01
              System Software, the versions of PreInstallApps (MEAP Administration Software) on this System Software CD
              should be used.
              5. If an imageRUNNER 2270/ 2870/ 3570/ 4570 being upgraded has a BootROM version of v3.30 or less, the
              BootROM should be upgraded first. The copier should then be rebooted and the remainder of the items upgraded.
              The ALL file automatically does the BootROM first, followed by a message to reboot.
              6. For the imageRUNNER 2270/ 2870/ 3570/ 4570, the definitions of the ON and OFF values for “Receive Limit for
              Each Function” under Additional Functions>System Settings>Device Information Delivery Settings have been
              switched. The default value has also been switched so the default behavior remains the same. The current
              definitions are:
              a. ON – Cannot receive (Default)
              b. OFF – Can receive
              • sangsik
                I beg to
                iR4570 Firmware eng,kor,jap
                kissik@chol.com
                Thanks.
                • alybaba000
                  Please send me the Firmware for canon ir2270 machine
                  any one can email me the firmware for canon ir2270
                  I tried to use one of the ir3320i but I have some problems at working of the machine and always have the error E000602-0102
                  I want the original firmware for this machine to try it
                  Thank you
                  my email
                  aly.m.abdelaziz@gmail.com
                    • 16083
                    Thank you
                    my email
                    U can not use iR3320i Firmware on a iR2270
                    U better put in a service call, if u tried doing that
                    • Dsblack
                      Canon ir2270
                      Hi Guys im New here.i have problem with Canon ir2270 error code E602-0001 and i want SST & Firmware 4 it can u help me sent it by email dsblack999@gmail.com.THK U
                      • Dsblack
                        Canon ir 2270
                        Hi guys anyone can help with Canon ir2270 error code E602-0001,i need
                        the SST & Firmware please i would be very Appreciate!!!
                        • JustManuals
                          • Jan 2006
                          • 9838
                          Re: iR4570 DCON Firmware
                          Yes, but you can't afford it.
                            • 16083
                            Re: Canon ir 2270
                            u also need a OEM HDD + Knowledge of SST
                            This is what u try first
                            In service mode Copier / Function / System & select HD-CHECK followed by pressing OK key. This check will count backward from 99% & run for approx. 10 minutes . The results of HD-CHECK will be displayed in LCD
                            1. OK
                            2. NG { hardware } may need new HD, try HD format 1st.
                            3. NG { software } restored / alternative sector } is displayed. Will need to install new system software.
                            When HD-CHECK is complete run HD-CLEAR in service mode Copier / Function / System then select HD-Clear followed by the OK key. HD-CLEAR will initialize the partition specified by CHK-TYPE. Once complete you will need to re-boot machine. After clearing the HD the boot process will take longer then return to normal.
                            • copytex
                              Hi Teckat,
                              Do you have the firmware for this. Really appreciate if you can send me at allan@copytex.com.my
                              Thank you!!!
