Canon 4050 jinx
  • Gman
    • May 2025
    Canon 4050 jinx
    We recently took an old 4050 as a T&M call for jamming. Replaced some broken drum picker fingers, now have blanks. Does anyone remember this dino? Please help if you can.
  • kwazimoto
    • Jan 2007
    • 199
    well if you took the drum out of the machine if is the primary in place and second the dv unit handle locked back over ???
    • Gman
      Thanks for the suggestions Kwaz. Everything back in place. Checked power from HV- checked dead with one meter & good with another. May have had bad batteries
      • Gman
        Problem solved! Bad MC
        • Auzzie
          • 10
          Could be the corrona wire cleaner some times that stay on wire causing blank.
            • 22929
            I know you've got it solved.
            I would have guessed a shorted s/t unit. That would have accounted for poor separation (i.e. broken drum claws) and blank copies (transfer loss).
