Canon IR2018 ERROR
  • media4u
    • 20
    Canon IR2018 ERROR
    Please help, I have on Canon IR2018 error mesage close front/left cover.
  • rabib
    • 63
    hi media4u
    4shared.com - online file sharing and storage - download Canon_iR2016_sm_pc.rar
    • remielee
      Technical Analyst
      • Mar 2010
      • 140
      try to open and close if the problem still occured.
      SOLUTION
      check the switch of the door if its working you can remove the front door and the cover upper pannel, then using tester(V.O.M) set the v.o.m in ohms X10 test the continuity of the line from the door switch and the side door switch to the power supply.
      note:
      one line from door switch to the side door switch is connected both and the other line goes to the power supply.
      if the line has no connection the error (open front/side door) will appear.
      hope it will be help you!
      • media4u
        • 20
        Thank You rabib!
          • 16083
          if it ohmed out and tested ok/ between power supply J112 & door switches / check your 24vDC from PS/ of not replace PS
          /If 24VDC is found at J12 on the power supply, check the DOPEN signal at J215, pin 7 on the DC Controller to be sure it changes state. Open and close the door, to check the signal. If the signal changes state, replace the DC Controller
          • Kenny105
            IR 2018
            good day
            can you please advise how to enter the service mode on IR 2018
            thanks in advance
            • remielee
              Technical Analyst
              • Mar 2010
              • 140
              Originally posted by Kenny105
              good day
              thanks in advance
              • Gleq
                • Feb 2007
                • 72
                and please if your not sure get a tech's support
                gud luk
                • DoneyPunch
                  didn't mean to hijack the thread but. would the same key sequence work on image runner c1022i>? i tried additional function, 2,8, additional function and it didn't work. ( actually the button for additional function becomes the word "done" after you you start entering the number. Which screen do you actually do these key inputs?
                    • 16083
                    for 1022 = Enter the Service mode. (Main Menu > 2 > 8 > Main Menu)
                    If changing a setting in service mode, turn OFF/ON the main power
                    switch.
                    • gac
                      Good day.
                      Have a problem with Canon iR2018.
                      There are message on the screen: "Network download standby" and nothing works.
                      (*), 2 & 8 not working to.
                      Thanks.
