imageRUNNER ADVANCE C9075PRO Series
or imageRUNNER ADVANCE C7065 Series
**If an imageRUNNER ADVANCE C9075PRO Series or
imageRUNNER ADVANCE C7065 Series machine requires flexibility
when using various stocks, enable the following in Service
Mode Level 1:
COPIER>OPTION>DSPLY-SW>IMGC-ADJ>0 TO 1
This Service Mode enables the end user to adjust the image position,
secondary transfer voltage and tail end white patch correction
in Paper Type Management Settings. This will enhance the end
users capabilities to ensure optimal color output on specific paper
stocks.
**When installing a new imageRUNNER ADVANCE
C9075PRO Series or imageRUNNER ADVANCE C7065 Series
main engine, be sure to execute Auto Correct Color
Mismatch, Shading Correction and then Full Auto Gradation
Adjustment. This will ensure optimal color quality output
including halftones and robust color.
Mode Level 1:
stocks.
