IR400
  • chucklima
    IR400
    When copies exit paper comes out crumpled, checked fuser unit looks good, it seems to me exit unit but I could not indentify what exactly.
    Does anybody knows what could be?
  • Copier_Guy
    • 543
    Is the fixing cleaner roller in good shape? It is called the fixing heat sink in the documentation. It builds up with sticky toner and may need replacement.
    • CanonHPTech
      • Apr 2007
      • 235
      Try replacing the following (3) Delivery Rollers after the Fixing Assembly:
      External delivery roller FB4-2902-000
      Internal delivery roller FB4-2901-000
      Reverse roller FB4-2903-000
      As you are doing this check all of the bushings/bearings at the ends of these Roller Shafts and the path as it exits through the Delivery Assembly.
      Most of the time, if these Rollers have never been replaced or haven't been replaced in 300-500k copies, then replace them anyway. Good luck sir, please post your findings.
      The glass maybe half full, but less is more...
      Printer + Fax + Copier = Jack Of Many Trades,
      but Master Of None
      Color Copier = Not A Color Printer
      InkJet MFP = Not A Fax Machine
      B/W Copier = Not A Press
      Finisher = Deal Closer (salesman, not accessory)
      Copier Tech = Admin's Stress Ball (Scapegoat)
