DANKA NX 40 message error
  • rabib
    • 63
    hi teckat
    I have canon color-pass ps-nx40
      • 16083
      Originally posted by rabib
      hi teckat
      should work/Same set up as a Z40
      does the ps-nx40
      have a internal CD ROM drive ??/ if so easy set up
      2. Press the Menu button, select Print Pages > Configuration Page to print out a copy of the configuration page.
      3. Place the CD in the internal CD ROM Drive of the ColorPASS-Z Series or connect and external CD ROM drive for those models without an internal CD-ROM drive. For models with 2 System Software CDs, insert CD 1 into the drive, and then put in CD 2 when prompted.
      4. Press the Menu button >Reboot Server to reboot the ColorPASS-Z Series.
      5. The ColorPASS-Z Series should recognize the system software CD and automatically prompt you for Install Software.
      6. You will see the message on the ColorPASS LCD "All data will be deleted. Continue? Yes. Choose OK to continue.
      7. The ColorPASS-Z Series will display Installing on the LCD and if you have the Optional Monitor you will see Norton Ghost installing with a Progress Indicator.
      8. At the end of install the ColorPASS LCD will display "To complete install please remove the CD and recycle power." Remove the CD and reboot the ColorPASS
      9. When the ColorPASS reboots, on the LCD you will see "Creating system backup...", and on the monitor you will see Norton Ghost with a Progress Indicator.
      10. The ColorPASS will reboot and you must Log in as Administrator.
      11. Configure Setup using the Configuration Page. To Enter Setup, Right Click on the FieryBar at the top of the screen and choose Set Up Fiery.
      12. Reinstall fonts, Command WorkStation or custom simulations as needed.
