Canon ir3030 - bypass problem
  • kuby
    • Oct 2007
    • 1409
    Have a ir3030 and when you put paper in the bypass and select the bypass and copy from the bypass - everything is fine. The problem is when trying to print to the copier from a computer. It will not pull from the bypass. When you select (from the computer) the bypass, it says no paper and does not know what kind of paper is in the bypass. Is there a way to make it feed from the bypass through the computer? A doctors office is wanting to put some kind of insucance form in the bypass. What do I check on to see if it is set right? I have checked everything I know to try. Anyone have this problem before?
  • SCREWTAPE
    East Coast Imaging
    • 3396
    What does it say?
    "load paper"
    • teckat
      • 16083
      MAC or PC ??
      for PC-set the 3030 as the default printer/check your printer properties set up/ and your printer preferences selections . what print driver are u using ? do u have a fiery connected ?
      what does he expect to print on form ?
      • SCREWTAPE
        East Coast Imaging
        • 3396
        I always run into this with clients.
        I tell them to first set up the bypass on the machine and then select the bypass from the driver and print.
        • teckat
          • 16083
          could not have said it better/
          • SCREWTAPE
            East Coast Imaging
            • 3396
            They always ask, why must I have to do it that way?
            I tell em, Design feature, hehehe.
            • teckat
              • 16083
              use to tell customers on phone to hit any key to print
              • D_L_P
                Self Employed
                • Oct 2009
                • 1196
                The size and type that the print job is asking for has to match the size and type in the bypass otherwise you will get a mismatch error aka "load paper". It doesn't necessarily mean it is out of paper just that it can't find any matching paper.
                Right click on the printer-> properties-> Device Settings tab-> Form to tray assignment, set bypass type. I'd select every type except plain and click ok then apply. If this doesn't work then the print driver is being overridden by the program. If they are just printing from MS Office programs you can change the page setup defaults, but it sounds like they are using some non-microsoft app to print from, Meditec by any chance? Those programs override the print driver size/type/tray settings and of course you have no access to these files to know how they were setup. You just have to use trial and error when you tell the copier what paper type is in the bypass. I've had good luck with telling the copier there is Recycled or Color paper in the bypass.
                • teckat
                  • 16083
                  u think he is trying to transfer text to these forms in bypass tray/ once had a customer with odd size paper forms in stack bypass, trying to transfer data info from Omniform on PC to forms in bypass tray , can't remember if it ever worked
                  • kuby
                    • Oct 2007
                    • 1409
                    They are trying to print on letter size paper. I have set the bypass for letter size paper. It will pull from bypass when copying but not when printing from a windows computer.
                    • teckat
                      • 16083
                      REPEAT> did u check or adjust the following ???
                      • kuby
                        • Oct 2007
                        • 1409
                        Have tried copier at default no change. PCL5 driver. Checked printer properties and preferences. No fiery connected.
                        • D_L_P
                          Self Employed
                          • Oct 2009
                          • 1196
                          What program are they printing from?
                          It sounds like they are using a non-MS program to print since you are getting the "load paper" message. It is probably asking for a certain type of paper, which you will have no access to change at the program so you have to change it at the copier.
                          For example, in Meditec (or any DOS program for that matter) say the page setup is like this:
                          size=letter
                          type=plain
                          tray=1
                          When the job arrives at the Canon it asks for letter/plain/tray 1. Most of those programs were written for HP where tray 1 is the bypass and tray 2 is the main supply, but in a Canon tray 1 is tray 1 and the bypass is the bypass. Bypass is not an option in those programs and this job would print from drawer 1.
                          What we did as a workaround is this:
                          size=letter
                          type=color
                          tray=0
                          Tray 0 is auto select, and telling it type "color" will make it look for any drawer with that type loaded. Then you just load the form into the bypass and tell it it is color paper and it prints fine. Getting in touch with the person who setup the page setup in the program was not easy as they were in another state. If they have the type=form, the copier has nothing similar so you just have to use trial and error. There is an auto continue feature which you can turn on. But we need to know what program they are printing from.
                          And no I don't think he's trying to transfer text to the form in the byass aka variable data printing.
                          • kuby
                            • Oct 2007
                            • 1409
                            When you go to print from windows and select the bypass as the source, it pulls the paper out of the cassette instead of the bypass.
                            • teckat
                              • 16083
                              what happens when u print from one of the browsers/ i.e.> firefox/ie8/
                              here is another test/ temporally disable cassettes for printing in service mode /
                              APS 'Auto Paper Selection' is automatically set to On by default for all cassettes. Disabling a cassette for Auto Paper Selection will allow you to specify Auto in the print driver(s) and prevent the copier from pulling paper from the disabled cassette. If you need to print from that cassette, you must specify the cassette or drawer number in the print driver. To disable the APS/ADS for a specific cassette on the GP Series, do the following:
                              1) Press the Additional Functions key.
                              2) Hit Custom Common Settings.
                              3) Select the Drawer Eligibility icon.
                              4) Select the Printer Icon.
                              5) Go to the Cassette where the special paper is located and select Off.
                              6) Press OK, then Press Done.
                              To disable the APS/ADS for a specific cassette in the imageRUNNER and iR series, do the following:
                              2) Select the Common Settings option.
                              3) Scroll until you see the option for Drawer Eligibility for APS/ADS.
                              4) Depending on which model imageRUNNER being set, some of the following options are available for selection: Copy, Printer, Mailbox, Fax, and Other.
                              5) Once the selection of Copy, Printer, Mailbox, Fax, or Other is made, go to the cassette where the special paper is located and select Off.
                              After u disable cassettes for Print/ load paper in bypass try to send a job from PC to it / report back what happens
                              if u have MS WORD/ run this test -in this you should always in print /Options... select>button and make sure the Background Printing check box is disabled/ also
                              disable the collate check box/ put paper in bypass/select Bypass or MF tray / report back
                              can't remember but do u have this setting below on ir3030-
                              If this is set to Off, it will not disable the Stack Bypass, but will allow the print driver to determine the size without generating a load paper error.
                              To Set 'Use Stack Bypass' to Off:
                              1) Select Additional Functions.
                              2) Select Common Settings and Press OK.
                              3) Scroll to Use Stack Bypass and select OK.
                              4) Select Off and then press OK.
