Can not scan with Canon IR105+!!!
  • tinnyjay
    • Oct 2009
    • 663
    Hello!
    I have conected my IR105+ with my pc through network conections and i use as a printer,but as a scanner i can't.
    I have installed Network Scangear and i discover my IR105+ after i set it to Online status,but when i click to connect or to launch the scanning aplication,nothing happens.
    Somebody helps me?
    "Who loves the roses,must also bear thumbs"
  • teckat
    • 16083
    Originally posted by tinnyjay
    Hello!
    Somebody helps me?
    The network scanner to be used with the ScanGear Tool enables scanning with
    Network ScanGear.
    ***** No scanner is selected during Network ScanGear installation, so this
    operation is required before use.
    Click the Start button, then select Programs – Network ScanGear
    Select the scanner to be used by either of the following methods.
    - Click the Discover button to search for scanners on the network and display the results in
    the list of scanners. Click the scanner to be used in the list, then click the Select button.
    - Click the IP Address button to display the IP Address dialog box. Enter the scanner IP
    address in the boxes, then click the OK button.
    IMPORTANT
    • With Network ScanGear, a scanner can only be used if it is in the same subnet (network with
    the same network ID) as the computer in which Network ScanGear is installed. When
    searching for scanners, only scanners within the subnet will appear in the list. When you
    specify a scanner IP address, it is not possible to specify an IP address outside the subnet.
    NOTE
    • After selecting the scanner, you can click the Test button to check that the selected scanner
    can be used.
    • tinnyjay
      • Oct 2009
      • 663
      Network ScanGear.
      IMPORTANT
      NOTE
      can be used.
      Yes,i did like this.
      After testing it says "The selected scanner is available for scanning".
      After selecting scanner in the list,i click on select and nothing happens.
      I have tried 3 different versions of Network Scangear and nothing at last.
      • D_L_P
        Self Employed
        • Oct 2009
        • 1196
        Canon Network Scangear is just a utility to setup the driver, you can't actually scan anything with Canon Network Scangear. Open a program like Word and as long as you have the MS photo editor plug in you can click Insert-> picture-> from scanner. Select Network scangear as your scanner and hit scan, the Canon TWAIN driver will come up and you can change the DPI/exposure/contrast/margins or if it scans from the glass or ADF.
        If you select Network Scangear as your scanner and when you hit scan and nothing happens try turning off your firewall.
        If you select Network Scangear as your scanner and when you hit scan you still can't scan see this thread.
        • teckat
          • 16083
          look in here
          Canon Scanning Support Page
          • SCREWTAPE
            East Coast Imaging
            • 3396
            As noted by DLP, you would need to use a application program, word, adobe acrobat standard or professional.
            • bnmand
              • Sep 2008
              • 383
              My favourite program to use is Adobe Standard. You can scan straight to a PDF, get OCR performed, get the page automatically rotated up the right way (if it has typed text on it) etc.
              If you know how you can work out what registry settings etc. need to be set and include it in a login script or in group policy or something. Check to see that Network ScanGear is installed and install the relevant files. This can be useful as each user that logs onto a machine has to setup ScanGear separately. However with a script this is setup automatically!
              • teckat
                • 16083
                click and read link below / i think this link poster is on the money with TWAIN conflict
