imagePRESS-C1 _ imagePRESS-C1+/New Countermeasure for 0108 Jam Codes
  • teckat
    • 16083
    A countermeasure to prevent 0108 Jam Codes.
    Products Affected:
    imagePRESS-C1 =All Serial Numbers
    imagePRESS-C1+ =TBD
    Serial Numbers Affected:above
    Paper fed from the Cassettes up through the Vertical Path are susceptible to jams at the Guide Plate on
    Right Vertical Path Door. In order to prevent this, the Crossing Guide Sheet (FC8-8836-000) will be
    introduced.
    Attach the Crossing Guide Sheet to the Guide Plate on the Right Door.
    Guide Plate
    New Crossing Guide Sheet
    (FC8-8836-000)
    Installation:
    1. Clean the attachment position on the Right Guide Plate with alcohol.
    2. Remove the backing paper from the double-sided tape on the backside of Crossing Guide Sheet.
    3. Attach the Crossing Guide Sheet to the attachment position on the Right Guide Plate so that the
    crease on Crossing Guide Sheet is aligned with the edge of Guide Plate.
    The Crossing Guide Sheet must be attached so it is in between the ribs of Guide Plate and does not ride on
    the ribs of Guide Plate.
    The Crease on Crossing Guide Sheet is aligned with the Edge of Guide Plate
