IR3100CN with error code E0067
  • xlbizs
    • Jun 2009
    • 66
    Dear all,
    we have one Canon IR 3100CN with error code E0067 during system warm up. while on/off the system still the same. how to solve this problem.
    thank you.
  • teckat
    • 16083
    Originally posted by xlbizs
    Dear all,
    thank you.
    what is sub code next to E067-XXXX ?
    Error code E067 indicates a High Voltage error
    CHECK DRUM LIFE % in service mode
    Your Drum is most likely old
    Check your primary transfer roller
    • SCREWTAPE
      East Coast Imaging
      • 3396
      Replace your drum..
      • xlbizs
        • Jun 2009
        • 66
        Dear All, the error code is E067-0110, we change the drum from the other IR 3100CN which is working one, but still having the error code during the warm up.
        teckat, can we reset the drum life.
        thank you.
        • SCREWTAPE
          East Coast Imaging
          • 3396
          The symptom can also occur because the tension spring for the primary transfer roller on the front side of the intermediate transfer belt came off. Check and make sure the spring is securely installed (item 21, shown below).
          • teckat
            • 16083
            item 21 here/ as screwtape quoted
            [ATTACH=CONFIG]4399[/ATTACH]
            fu5-2049-000
