On a couple of my c3170s the customer has complained about a line. I have found a line burned onto the drum from front to rear, as if the charging roller stayed on and burned it; I replaced the drum. What could cause this and how to prevent it in the future?
c3170 burns a line on the drum
simple fix/ U need the software update that addressed this issue
line caused by the charging roller remains on the surface of photosensitive
drum
A modification is made, so that the charge to the charging roller is
disabled at the emergency stop. upgrade the DCON > DCon 45.01
Make sure u have Firmware 45.01 or later+**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
That sounds more like it, Charm5496; Thank you for your input. Where can I get or buy the latest System Software for the iR-c3170?Comment
That is exactly what I am getting, Teckat, thank you for your reply. I will try to get the latest System Software and install it.Comment
