Canon IR-3235i, Blank Key Pad
  • SF Tech
    • Sep 2009
    • 14
    Hello,
    I got CANON IR-3235i, very low meter with Totally Blank Key Pad, Can not Copy/Print/Scan, I know it is NOT the key Pad (tested on other machine). Copier makes some noise/like ready to copy
    Thank's for any help.
  • teckat
    • 16083
    Originally posted by SF Tech
    Hello,
    is the green power button on ??
    If u tested the entire control panel on another printer/ it cant be the Inverter PCB ,
    so u may have a bad Memory Dimm WA7-5211-000
    or
    If the Main Controller "registered value" ID does not match the REAL TIME CLOCK (RTC) ID, the Main Controller Malfunctions; preventing the LCD display from powering up or no power to unit. By shorting JP1 on the Main Controller it will clear the RTC "registered value", to correct the ID between the Main Controller and RTC Circuit.
    Procedure:
    1.
    Turn OFF the Main Unit.
    2. Either unplug the power cord from the wall.
    3. Remove the rear cover of the Main Unit.
    4. Below the left leg of the Battery, jump JP1 for 3-5 seconds.
    5. Plug in the power cord and turn on the Main Unit.
    6. Verify that the Main Unit powers ON and that the LCD display works.
    7. Re-install the rear cover.
    • SF Tech
      • Sep 2009
      • 14
      Yes, GREEN Power is ON (only light)
      I tested the entire Panel, It was OK
      Do I need to jump JP1?
      • teckat
        • 16083
        give it a try/ follow instructions
        • SF Tech
          • Sep 2009
          • 14
          One last issue, To jump it and turn power on for 3-5 sec. together?
          Thanks much
          • teckat
            • 16083
            Thanks much
            yes/
            hold jump/turn on/release jump/after 3-5 sec/ check panel
            • SF Tech
              • Sep 2009
              • 14
              Thank You, got it working,
              Any reason why on almost new machine?
              • teckat
                • 16083
                thanks, no word on any other fix from Canon
                • Dan Dryer
                  • Jan 2008
                  • 57
                  It's a firmware issue. You need to upgrade the System Software to version 36.01 or later to prevent any recurrence of the problem.
                  • teckat
                    • 16083
                    Originally posted by dan dryer
                    it's a firmware issue. You need to upgrade the system software to version 36.01 or later to prevent any recurrence of the problem.
                    good thinking
                    [ATTACH=CONFIG]4523[/ATTACH]
                    • SCREWTAPE
                      East Coast Imaging
                      • 3396
                      Confirm. Must be 36.01 or later. If this is a new machine then the firmware should be later than 36.01. The latest System software for this machine is 42.01.02. Confirm this.
                      • jonezy999
                        just one copy??
                        • Feb 2010
                        • 952
                        Can anyone point a fool in the direction of this firmware. I have access to the Canon Partners site, but can't seem to find it there. Also, will I need to upgrade one version at a time or can I just go with the latest version?
                        I have not failed. I've just found 10,000 ways that won't work. ~Thomas Edison
                        • teckat
                          • 16083
                          TP10_093b-1.pdf
                          • jonezy999
                            just one copy??
                            • Feb 2010
                            • 952
                            Originally posted by teckat
                            [ATTACH]9927[/ATTACH]
                            Thanks Tekcat
                            +rep
                            • teckat
                              • 16083
                              The Dude.jpgWelcome~~~~~~~~~~~~~~~~:>
