ir2200
  • kittybo
    ir2200
    i have a ir 2200.....keeps coming out for e0007...have changed fixing film( 3 times)....and lower roller....everytime paper is wrapped round film....customer using same paper for last 3 years ,machine using canon toner....any ideas????
  • teckat
    • 16083
    sounds like voltage issue
    check all your wall voltage /especially between Neutral n' Ground
    should be 0.3v to 0.5v
    • D_L_P
      Self Employed
      • Oct 2009
      • 1196
      3 new films with paper wrapped?? Are they running lots of sky shots?
      Adjust Copier->Adjust->Blank->Blank-T. Adjust your lead edge void. Give it 1/4 of an inch to be safe.
      • SCREWTAPE
        East Coast Imaging
        • 3396
        To add to DLP.
        Blank T is to enter a value for the image leading edge non-image width. <Setting range> 0 to 2362 (Default: 0) Setting a greater value increases the width.
        Blank B is to enter a value for the image trailing edge non-image width. <Setting range> 0 to 2362 (Default: 0) Setting a greater value increases the width.
        Blank TE is to enter a value of the non-image width in image main scanning direction (left, right). <Setting range> 10 to 50 (unit: 0.1 mm), default: 25.
        • kittybo
          thxs for reply ...will try on mon..repost to let u know
          • kittybo
            made adjustment blank-t increase>>>>so far so good....thx for help
            • teckat
              • 16083
              good tech support, is hard to find
              click on pic
