query re: ir c3200n, print system
  • downhiller67
    • May 2010
    • 67
    good day!
    ou
    i already installed successfully the driver on this machine but when i about to test print, no print out came out, i can access the system thru IP add., when i ping it, it is conneted. what must be the problem? could somebody please help me, thank you.
  • teckat
    • 16083
    Originally posted by downhiller67
    good day!
    ou
    To verify the Main Controller Firmware:
    Enter Service Mode, Press Additional Functions, 2 and 8 simultaneously, then Additional Functions again.
    Press Copier, then Version.
    The PS/PCL must have a version number, not dashes (---). If not, the main controller (MN-CONT) must be flashed up accordingly. (Make sure you have the Network Printer Kit installed. Verify by looking at the Boot ROM version. It should have an N designation after the version.)
    . If you have the correct version of System Software you most likely have the Dept. ID feature turned on. On the imageRUNNER the Dept. ID feature is for walk up copying and for network printing, unlike the Fiery family of imageRUNNERs that use the Dept ID for walk up copying only. The print job needs to be sent along with a Dept. ID and, if set, a password in order to released to print. This is done in the driver under the Device Settings tab .
    If you cannot print and the jobs are stuck in queue on the PC or the server, check the following settings:
    Verify that the protocol (LPD, RAW, SMB, etc) being used to print from the computers is enabled in Additional Functions on the copier.
    Make sure Address Range Settings or Receiving MAC Address Settings are turned off or configured correctly.
    ***The above settings are located in Additional Functions>System Settings>Network Settings>TCP/IP Settings.
    • SCREWTAPE
      East Coast Imaging
      • 3396
      good day!
      ou
      What driver are you using?
      Is the job hitting the machine ?
      Check system monitor>print tab
      • downhiller67
        • May 2010
        • 67
        thank you very much on the replies.
        • krazeekidz3
          • 48
          I had this same problem and it turns out there was a password for each individual user/computer attached to the copier/network.
          • SCREWTAPE
            East Coast Imaging
            • 3396
            Try posting some of the infomation from the P-print info like, MN-CON version, Bootrom version and PS/PCL version.
            We can then determine what your issue may be.
            • smiley
              • Aug 2008
              • 615
              try to look for the log on print and see what is the result of your print if ng im sure you dont have n bootrom or your ufr board is not installed.
              there is no glory without sacrifice
