canon lbp5960
  • srecko
    • May 2010
    • 1
    canon lbp5960
    Hi guys, I have a problem on a Canon color printer lbp5960. is totally dead, no signal. Since I do not have such a printer to try to replace the electronic information board please if anyone has had this problem.
    Srecko
  • SCREWTAPE
    East Coast Imaging
    • 3396
    When you say totally dead, there's no power??
    • teckat
      • 16083
      Srecko
      Hold down the Online Key and the Cancel Job Key and turn the printer on.
      then hit the > Settings Key
      You should see service mode on the screen (you may have to hit enter key first). Then use the up and down keys to scroll through the menu until you get to FUNCTION, press enter, then you should see Clear ERR, Hit enter again then restart the machine.
      Not sure if that will clear your particular error, but have a go and see what happens. Good luck with it.
