Canon IR105+ grey background....please help me!
  • D_L_P
    Self Employed
    • Oct 2009
    • 1196
    #31
    Nice job fixing it yourself!
    • tinnyjay
      • Oct 2009
      • 655
      #32
      Originally posted by teckat
      If the machine is not used (no keys are pressed) for a period of about 15 minutes, the machine automatically enters the Low Power Mode. The Low Power Mode reduces the temperature of the machines fixing unit and thereby conserves energy. This function meets the ENERGY STAR Program for energy efficiency. To start operations, press (Energy Saver). Pressing the control panel power switch also reactivates the machine. NOTE:
      • There will be a slight delay when starting to use the machine next time.
      • The touch panel display turns OFF when the machine enters one of these functions.
      • You can print data sent from a computer even when the machine enters one of the energy saving functions.
      To change the amount of time it takes for the machine to enter the Low Power Mode (the default settings is 15 minutes):
      1. Hit (Additional Functions) -> [Timer Settings] -> (down arrow) -> [Low Power Mode Time].
      2. Enter the desired time period with the up or down arrows, and press [OK].
      * The Low Power Mode Time settings are 10, 15, 20, 30, 40, 50 minutes, 1 hour, 90 minutes, 2, 3, or 4 hours.
      3. Press [Done]. The specified mode is set, and the display returns to the Basic Features screen.
      When i open my canon ir105+ in browser(e.g moxilla firefox) and go to Error Mesages it says me like this :
      Fixing Unit Error.
      Check the fixing unit.
      I dont know what does this mean
      "Who loves the roses,must also bear thumbs"
      • teckat
        • 16083
        #33
        have u walked over to printer yo see what is going on ??
        exactly what does it says on machine / check machine error log/
        is printer showing an error/ or message on panel
        Check to see if the fixing temperature is increasing in service mode; COPIER>DISPLAY>ANALOG>FIX-C and FIX-E. If the fixing temperature is not increasing, check the duplex connector, both on the duplex unit as well as the rear of the copier. Assure there is no damage, or paper caught in the connectors.
        • mrfixit51
          Lead Service Technician
          • Oct 2008
          • 1975
          #34
          Fixing Unit Error.
          Hey Teckat, do you know if a "cleaning web low" message would show on the RUI as Web Low, or possibly give that general message, "Check the fixing unit", causing the operator to actually walk over to the copier to read the message panel in the bottom of the screen? That is all I can think of...
          • teckat
            • 16083
            #35
            In RUI under Additional Functions/ System>I believe in Edit u can check/un-check something called Status display/ also there is an Enable PoP UP Window/ someone may have entered a message in there for "check fixing unit"
            Have not heard of a fixing message prompt/ a web message prompt, may under device settings in certain models
            • teckat
              • 16083
              #36
              on the 105+ RUI there is a Error Information tab under Device
              • tinnyjay
                • Oct 2009
                • 655
                #37
                The problem it's not if is showed a message like "Fixing Unit Error",but why is showed!
                • teckat
                  • 16083
                  #38
                  [ATTACH=CONFIG]4700[/ATTACH]
                  fixing web is low message is from machine durable counter
                  web is in fixing unit / !!!!!!!!!!!!!!!!!!!!!
                  what does it say on printer control panel ?
                  bottom line is the machine working
                  • D_L_P
                    Self Employed
                    • Oct 2009
                    • 1196
                    #39
                    The copier is working?
                    I think MrFixit had the correct answer. The web counter needs reset.
                    Service mode, Copier-> Counter->Misc-> Web, highlight web and hit Clear key on control panel.
                    After that you may need to clear the message board also, Additional Functions-> System Settings-> Clear Message Board.
                    • Herrmann
                      • Jan 2006
                      • 792
                      #40
                      just a thought.....maybe, the web is really done and need replacing? before ressetting the counters have at least a look at the web
                      If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
                      • teckat
                        • 16083
                        #41
                        message says Web is Low> not replace Web !
                        it has taken two days for poster to inspect printer
                        • SCREWTAPE
                          East Coast Imaging
                          • 3396
                          #42
                          If the web is done there would be a E005.
                          • Herrmann
                            • Jan 2006
                            • 792
                            #43
                            absolutely right, screw, but i would suggest to replace it before the e005 appears, thereby leaving the mashine useless until a technician shows up. I and You (i am sure) know murphy, and critical calls always appear friday afternoon, ruining your start in the weekend , so, if in doubt, replace it, its only 15 euros (12 dollars, i think) and avoid trouble.
                            • SCREWTAPE
                              East Coast Imaging
                              • 3396
                              #44
                              I hear that..
                              • tinnyjay
                                • Oct 2009
                                • 655
                                #45
                                I just searched for Fixin Unit Error in Service Manual,but there is nothing about this.
                                As you say,this can be connected with Fixing Web is Low.
                                I will change Fixing Web and i'll show you the results.
                                I can buy Cleaning Web for only 30 Euro here in Albania and by the way,i need to buy parts and toners for Canon,Ricoh and Toshiba in Europe cheaper than i really buy here in Albania.
                                Who can help me with this
