Ir4600 c'ant power on don't work
  • mscomp
    hello i have one ir4600 i have a big prob with it now
    the machine not work, when i power on the machine juste a led green on and the machine not work no think hapned just led green only pleza urgent how to slove this prob
    my english is so bad i speak frensh
    • 16083
    does printer warm up ??
    green light is good/ did u check the LCD Display contrast button
    can u send prints to print out ??
    • mscomp
      no no think hapened just green led only i change hhd ram all but same prob pleaz help
        • 16083
        what did u do to the HHD / OR why did u clear ram
        • mscomp
          the tecnition has chanded it because he hav'nt khnow the trus brobleme he tested all but the priter not work
            • 16083
            u better him back/ or call his boss
            • mscomp
              How we can slove this prob
              • mrfixit51
                Lead Service Technician
                • 1975
                I am not sure what model you are dealing with, ir4600 is not used here in the U.S., but the symptoms sound to me to be caused by either a bad main controller, or the all night power supply. The all night power supply provides 3.3 volts to the main controller, and if this signal is missing, you have the symptoms you have described. I just fought an iR3245 with similar symptom, and I did have the 3.3 volts, so I replaced the main controller and resolved my customers problem...
                  • 16083
                  are u the tech who changed or did something to Hard Drive ??
                  • mscomp
                    no its my machiche but i am not the tech
                      • 16083
                      why don't u contact tech who worked on printer/ only that person knows what they did to your HDD
                      • mscomp
                        the prob is on HDD ' printer dont worm on
                        Tech he is who tld me to poste For Helps because he havn't know with the prob
                          • 16083
                          tech needs to return and re load firmware on HDD/ or call a reliable Canon trained
                          service person
                          • mrfixit51
                            • 1975
                            service person
                            I agree with Teckat, and the one thing to take away from that advice is Canon trained , even if I don't know the answer, as a certified Canon tech, I can contact Canon directly for advice on any problem. That is the true value in being Canon trained.
                            • mscomp
                              thanks for all when my machine is broken i send his to a good tech he tray with an other hdd forme the same model ir 4600 after this the ohter machine has broken to with the sam prob we have the firmware of this machien on CD but he dont khnow how to updut HDD he make only hardware solution
                              very thaks to all
                              where i can contacte service canon algeria
