E744 on iR3570
  • sgcopiertech
    • Aug 2025
    E744 on iR3570
    hi guys
    I got a 3570 with C bootrom
    when i plug in an N bootrom + HDD
    I got this e744-3030
    checked the manual, but got no info on the "3030"
    any info?
    thanks
  • Peter Sim
    • Sep 2008
    • 445
    Originally posted by sgcopiertech
    hi guys
    any info?
    thanks
    When you add to N bootrom ,what you need is add another sd ram 256 to total 512 MB.
    • teckat
      • 16083
      hi guys
      any info?
      thanks
      Enter service mode to check the amount of RAM recognized by the machine.
      COPIER>DISPLAY>ACC-STS>RAM
      The machine should display 512MB of RAM installed.
      imageRUNNER 3570 SKV00001 ~ SKV62419
      For manufacturing convenience, the DIMM configuration has been changed from using 2x256MB memory
      DIMMs (WA73296-000) to 1x512 MB memory DIMM (WA7-4625-000).
      When replacing a DIMM, use (Qty 1) 512MB DIMM or (Qty 2) 256MB DIMM. The 256MB DIMM will
      continue to be supplied.
      Be careful not to install a 512MB DIMM into a machine with 512MB already installed. Adding 128MB,
      256MB, or 512MB DIMM into the additional open slot will render the machine inoperative.
      The 512MB DIMM can be mounted on either of the slots.
      The additional 256 Memory DIMM is no longer provided in the Multi-PDL Printer Kit.
      • sgcopiertech
        case closed
        add 1 256mb
        thanks peter for quick reply
        thanks teckat for the wonderful and very useful info
        • teckat
          • 16083
          welcome~~~~~~~~~~
          • Alan Aya
            hi guys
            any info?
            thanks
            Add another piece of 256MB RAM will solve the problem
            • saidone
              • Mar 2012
              • 12
              Re: E744 on iR3570
              Hello everyone,
              I have the same problem like this. My bootrom ver 08.38 and ver 06.36 with the pair 256 of RAM, but the machine not functioning its still E744-3030. I still cannot upgrade the machine.
              • teckat
                • 16083
                Re: E744 on iR3570
                Originally posted by saidone
                Hello everyone,
                The E744-3030 -- can be caused by an insufficient or damaged RAM installed in the machine. Enter service mode to check the amount of RAM recognized by the machine.
                *NOTE Some machines will have 2x256MB SDRAM DIMMs installed and some will have 1x512MB SDRAM DIMM installed.
                remove>clean ends> re-seat/ or swap to check
                • saidone
                  • Mar 2012
                  • 12
                  Re: E744 on iR3570
                  when I installed bootrom ver 03.30C, the machine is OK, the 2 x 256MB of RAM are good, but the 2 version of bootrom cannot be used. The machine cannot booting at all.
                  • teckat
                    • 16083
                    Re: E744 on iR3570
                    U have old BOOT ver.
                    Latest Firmware-----------imageRUNNER 2270/2870/3570/4570
                    05-10-12
                    System Software v41.01.01
                    BootROM v11.43
                    Language v41.01 (JEFIG)*
                    RUI v38.01
                    re-flash your BOOT ROM / Or have a service person update firmware with SST
                    Copier Boot ROM Part Number=FM2-4837-000
                    The Boot Rom slot on the Main Controller is the same size as the DCON Dimm slot on the DC Controller. Hastily replacing this chip without confirming the correct slot will damage the chip. NOTE: If you are installing a network boot rom and it is damaged, you will need to contact the TSC for the replacement procedure.
