IR 5000 series
  • aabarnes1
    • Mar 2009
    • 619
    IR 5000 series
    We are about to take delivery of our first 5 of these boxes- a mixture of 45 amd 51 cpm. Is there any advance stuff you guys think I might need, TIA, cheers. ( known problems, gliches)
    Grant me the serenity to accept the things I cannot change.
  • teckat
    • 16081
    Eight years of information would take up too much space here/ play it by ear/
    check your firmware versions first/ print out data sheets for each machine to compare firmware ver's.
    are u receiving any type service history logs with them ??
    Last firmware update was 2006/2007/2008
    5000=v20.01
    5000i=v47.01 w/controller upgrade kit
    5000i=v9.01 w/out kit
    5000d/6000d=v83.02
    5020/5020i/6020/6020i=v59.51
    • D_L_P
      Self Employed
      • Oct 2009
      • 1195
      Very solid copier. Excellent choice. Aside from the usual items (fuser rollers, feed tires, corona wires) very few problems. Good idea to learn how to reset a fuser code (E001, E003) which might come up once or twice a year.
      One very minor issue is adding toner. I'd say like 50% of the ones I've worked on the latch that holds the bottle down while you add toner is broken. Just be sure to press down on the bottle when you pull that slider out, or replace the broken housing. I've noticed there is an overflow chamber that gets filled and makes it harder to add toner.
      Overall one of Canon's best though IMHO.
      • teckat
        • 16081
        true statement, if you have a trained tech available in your location
        • aabarnes1
          • Mar 2009
          • 619
          5000=v20.01
          5000d/6000d=v83.02
          These are brand new machines so theres no history
          • D_L_P
            Self Employed
            • Oct 2009
            • 1195
            I don't mean to be so negative, but "brand new"??? Like they have sat in a warehouse for 5 or 6 years? I'd just be sure to look them over good, since there have been some posts on E3xx codes and how to reset meters. I'd pull out the drawers and shine a flashlight behind everything, there shouldn't be any paper dust, connectors shouldn't have any wear, plastic housings for the fans shouldn't be warped or cracked. Even if it sat in a warehouse for years it should still have that NEW look to it.
            But on the good side, if they are new it is not uncommon for them to go 500,000 copies before the 1st service call which was usually the web running out. Not a guarantee it will go 500k, but I've had many ir5000's in my territory and I would highly recommend them. I still have a dozen or so, one with 4 mil at a school running monthly newsletters, I only have 3 or 4 service calls a year on it.
            • teckat
              • 16081
              Brand New ?? u mean they were never turned or installed before u received them ?
              I find it hard to believe/ what warehouse Canon Dist. did these come from ? USA OR EUROPE
              • aabarnes1
                • Mar 2009
                • 619
                The machines are the Image Runner Advance 5030, 5045i with fiery and the 5051 models. They came from a dealer in Dublin right out of the box. The company is Office Technology Ltd, based in Dublin. We are Ricoh/KM dealers but have a customer that insisted on canon colour machines so we got these. I thought they were a relatively new model.
                • teckat
                  • 16081
                  You did not say they were the new ADVANCE SERIES of printers in your first post/ there is a big difference between an iR5000 and the iR Advance models.
                  I can send u a new tech. pub on iR Advance install tips from Canon.
                  PM me your e mail
                  • SCREWTAPE
                    East Coast Imaging
                    • 3371
                    That's a big difference.
                    From a 5000/5020 to a image runner Advance.
                    • teckat
                      • 16081
                      Will Finish Installs Later in Week
                      • aabarnes1
                        • Mar 2009
                        • 619
                        PM
                        PM me your e mail Did you get my PM?
                        Did you get my PM?
                        • teckat
                          • 16081
                          yes/ check your mail later
                          • D_L_P
                            Self Employed
                            • Oct 2009
                            • 1195
                            Errr......Well I made a good pitch for an IR5000 anyway. I don't know much about the Color IR Advance series, but if it is anything like an IRC3200 or IRC5180 I'd recommend it. Avoid an old beast known as the IR3100 and it's sidekick the IRC6800.
                            • teckat
                              • 16081
