IR3320 not entering the service mode to clear E000007 error
  • Klydon
    • Mar 2009
    • 243
    E007 does not need to be reset like a E001
    /agree with others you likely have a bad fixing film. There are some third party (Katun) fixing films out there you can get or at worst, a fixing film unit.
    While in there, check to make sure the pressure roller surface is smooth and that it has not become detached from the core of the roller.
    • kishkumar
      I have had a look at the fixing film and it looks fine and the pressure roller also looks fine. My multimeter has been playing up and therefore I couldn't test the resistance. Fixing film is about $20 more than the fusing unit. I couldn't find any cheap ones in Australia. I am waiting for Monday to order the fuser unit. I think there will be 5 days delay after that. I will keep you all posted.
        • 16083
        edge sensor in unit is blocked/ remove unit and adjust position
        • kishkumar
          #19
          Many many thanks to everybody who gave their inputs. I have just replaced the fuser assembly and everything worked fine. I didn't even have to clear the error.
          • SCREWTAPE
            East Coast Imaging
            • 3396
            #20
            Glad to hear your up running again.
              • 16083
              #21
