Canon irc3200 Warming up continuously
  • saaam
    • Aug 2025
    Hi i have Canon irc3200
    it Warming up continuously again and again i waited over 2 hrs still the warming up didnt stop
    need help plz
  • Blues Guy
    • Aug 2009
    • 216
    One of your drum unit assembly giving problem. Try interchange the drum unit assembly black color before trying other color.
    • teckat
      • 16083
      need help plz
      Also Check>>>>below
      Remove the Delivery Vertical Path Unit on the left side of the machine. You will see a photo sensor PS5 Fixing Feeder Unit Open/Close Sensor sandwiched between two micro sensors that actuate when closing the Fixing Feeder Unit. Clean that photo sensor as it fills up with dirt and dust. You may also experience an E004 0002 in the error history.
      Check in service mode, * 2 & 8 *, under Copier > display > Dens. Look at the value for each individual color. The normal value would be between zero and one. If you have a color with a value around four or five you have an issue with the toner/starter concentration level for that color. By replacing that color drum unit you will temporarily resolve the issue due to the Developer Assembly being incorporated with the drum unit, which has the correct toner/starter concentration.
      To resolve this issue replace the Toner Cartridge Drive Assembly, FG6-8999-000, and the corresponding drum unit at the same time.
      • Canuck
        Tech Specialist
        • 1713
        copier/display/analog.....is the fuser heating up?
        • teckat
          • 16083
          if fuser is not warmed up to temp, it would pop a E 000
          • SCREWTAPE
            East Coast Imaging
            • 3396
            There are cases with the drums causing issues like yours.
            • randall
              • Sep 2009
              • 73
              i had one 3220 do this, turned out to be PCI board creep in the main Cont. box. caused by customer excesive force with finisher/fuser attachment.
              power down, remove upper rear cover and right inner cover. reseat all memory and boot rom, then remove and reseat all PCI boards. then power up warmup should be approx 2 min. if this doesnt work remove and leave out the interface board(for controller) and Nic card then power up machine, does it warm up and allow copy faster? if yes replace them one at a time to figure which to replace. I think there was a techpub on the interface board having caused this symptom with no error code
              Some people may say I have a short temper, but I prefer to call it
              "A swift and assertive reaction to bullshit"
              • Canuck
                Tech Specialist
                • 1713
                Usually under normally conditions...but....just like when fixing/feeder photointerrupt is dirty. You SHOULD have to clear the E004 in service mode. You dont though...turn off and on and it clears. There is another post out here about a 5570 that the fuser does heat up,no errors. The first step in any logical troubleshooting would be to monitor if the fuser is heating up...it takes 1 sec to look at it in service mode...tech 101
                • teckat
                  • 16083
                  I know U don't have to Clear E004 in service mode on a 3200/3220/2620
                  Here is a reminder>>>
                  <CLEAR>ERROR
                  Clears error codes.
                  (Cleared error codes: E000, E001, E002, E003, E719)
                  1) Select this item, and press the OK key.
                  2) Turn the main power OFF/ON.
                  The reason is that the opening and closing of door or turning on/off re sets the circuit to the non-contact
                  thermistor & triac. E004
                  The reason u have to enter service mode for those others is to protect the customer & printer
                  • randall
                    • Sep 2009
                    • 73
                    I forgot to mention in my example the copier locked out on copy screen and you couldnt enter service mode to check analog
                    • teckat
                      • 16083
                      locked out/ u mean the keys do not respond ??
                      if u have a imagePass fiery connected to back of 3200/ turn it off/turn off 3200/ go in service mode/do a MN-CON to clear the locked up control panel / turn off 3200/ turn on fiery - then 3200/
                      • SCREWTAPE
                        East Coast Imaging
                        • 3396
                        Did this copier ever worked.
                        Whats the meter count?
                        Service history in the past 6 months?
                        • randall
                          • Sep 2009
                          • 73
                          the keys and the touch panel, if you were quick it allowed you to get to the main Svc mode screen then lockup. i left the c1 disconnected and still no go. only resolution was to reseat the boards.
                          • randall
                            • Sep 2009
                            • 73
                            yes copier worked fine until customer (or construction workers) moved due to office remodeling
                            total meter 730k
                            1 month ago replaced all tires d1-d4
                            2 or 3 months ago e677 system flash upgrade and c1 upgraded
                            6months back fuser replaced
                            • Van Steal
                              • 177
                              need help plz
                              A faulty toner bottle can cause this problem too. Check in service mode under display-dens to see which colour it is. You will find that one will be +/- 3%..
