Image Press C1 error code E000005
+ More Options
Posts
  • COCODIAZ
    • May 2010
    • 31
    [Error Code] Image Press C1 error code E000005
    Hello someone can help with this issue. thanks
  • teckat
    • 16083
    E000 0005
    During warm-up after the fixing assembly jam, the temperature does not rise after the specified period of time (600 sec.
    Reset in service mode: COPIER>FUNCTION>CLEAR>ERR
    Remove and Inspect Fixing unit/ if it looks ok-put back/ clr error / report back
    • hemai2005
      Professional Print
      • 108
      Originally posted by teckat
      E000 0005
      add to teckat
      check fixing web
      sigpic
      Learned a lot will become an expert
      • COCODIAZ
        • May 2010
        • 31
        Thanks a lot, I clear the err, and now is working. Very useful
        • teckat
          • 16083
          Reminder **Web Error is E005 0000/0001
          Best Bet is= Try a get a C1 Service Manual
          • otreb
            i have the same error code i clear the errors still has problem replace sensor still not working any help.
            • teckat
              • 16083
              when u can not clear a E000, U NEED TO REMOVE FIX UNIT TO INSPECT IT/ look for jammed paper inside/inspect heaters/thermistors
              check for a thermistor open circuit/paper wrap
              Fixing Method by lower fixing belt
              Heater=inside fixing roller 2pc (main heater/sub heater; integrated type)
              Inside inlet roller =1pc.
              Inside outside heating roller = 1pc.
              Control temperature
              Fixing roller 165 deg C (standby)
              Fixing belt (inlet roller) 95 deg C (standby)
              Outside heating roller
              200 deg C (standby)
              Fixing temperature detection
              Fixing roller Main thermistor THM1 (roller center; non-contact)
              Sub thermistor THM2 (roller rear end; contact)
              Inlet roller Main thermistor THM3 (roller center; contact)
              Sub thermistor THM4 (roller rear end; contact)
              Main thermistor THM5 (roller center; contact)
              Sub thermistor THM6 (roller rear end; contact)
              Fixing temperature control=
              during warm-up, standby, printing, last rotation, power save mode
              Fixing speed control
              down sequence (black-and-white, constant velocity only)
              Protective mechanism=
              A check is run for the following to cut power to the heater in the event of a fault.
              check on the temperature using the main/sub thermistor
              cutting the supply power using the thermal switch
              Fixing roller TP1 (roller front end; contact; operating temperature of 180 +/-7
              deg C)
              Fixing belt TP2 (roller center; non-contact; operating temperature of 130 +/-5
              deg C)
              TP3 (roller front end; contact; operating temperature of 220 +/-8
              deg C)
              Separation mechanism=
              -Separation Roller
              Separates paper from the fixing roller. Separates paper by pressing the separation roller of
              which first diameter is 20 mm dia into the fixing roller to generate a local curvature change.
              -Lower Separation Claw
              Prevents wrapping of paper around the fixing belt (as when paper is curling downward)
              Cleaning mechanism=
              fixing roller by using the collecting roller and taking up the cleaning web
              Fixing belt= none
              outside heating roller =by the cleaning roller
              Control mechanisms
              - cleaning web drive control
              - cleaning web length detection
              - belt/web/outside heating roller attachment/detachment control
              - belt displacement control
              • parsa
                cannot enter to service mode canon ir8500
                i peress * 2&8 * in key canon ir8500 about not entr
                why?????????????????
                help meeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
                • otreb
                  hey is *28* the 28 together or the same time that should work
                  • teckat
                    • 16083
                    You should post under help for iR8500-
                    THIS POST WAS FOR A IMAGE PRESS C1 ISSUE
