email functions canon irC3220
  • jschoen
    [Misc] email functions canon irC3220
    HELP Please!! I have been through the forums and can only find where to change the smtp ports. How do I set up the smtp server? I would like to be able to scan documents and have the machine send them to my user's email box. Any help will be trully appreciated. Thanks in advance!!
  • D_L_P
    Self Employed
    • Oct 2009
    • 1196
    The copier acts as an e-mail client just like any other workstation, not a server. You just need to tell the copier what the IP address is of your SMTP server and give it a sender's name, (and authentication if needed).
    Go Additional Functions-> System Settings-> Network Settings-> E-mail/I-Fax Settings. Enter the SMTP server and an e-mail address (it doesn't have to be a valid e-mail).
    If your SMTP requires authentication then you will need to setup an email box with user/password and add it at the Auth. Info button.
    • SCREWTAPE
      East Coast Imaging
      • 3396
      DLP gave you the right direction.
      The question is...
      Do you have universal send?
      • jschoen
        Thank you.
        Thanks a lot SCREWTAPE and D_L_P!
        I do not have the email option, or at least I don't think I do. I will check tomorrow morning. If I don't, how do I add it. Like I said, I found the location to change the SMTP port. Not sure how to check if I have universal send.
        Thanks again,
        james
        • SCREWTAPE
          East Coast Imaging
          • 3396
          You should see a send tab at the top of the control panel lcd.
          You should see, copy, send, mailbox or scan.
          • jschoen
            No Send
            Hey SCREWTAPE,
            I don't have a send. All I have is COPY ; MAIL BOX; and SCAN. Is this a feature we have to pay for or can we install ourselves?
            Thanks again!
            • jschoen
              Hey SCREWTAPE,
              Searched and found my answer, well part of it anyway. I see that universal send is an option we have to pay for but is it something easy enough we can install or should we have a rep come out?
              Thanks,
              james
              • charm5496
                • 2387
                To install the U-send function on a 3200 you have to a have a dongle and install a program that comes with the box. I would pay the 30 minutes of labor and have a trained tech come out an install it on the device. Or you might be able to work it out and have a tech install and configure the U-send for you and not have any head aches at all!!!!
                • jschoen
                  Thanks so much
                  everyone. We are calling the Canon rep.
                  Thanks again to everyone!! Have a Great!! Weekend!
                  • SCREWTAPE
                    East Coast Imaging
                    • 3396
                    Have a tech install it and help you set it up.
                    Hope everything works out.
                    Take care.
                    • SCREWTAPE
                      East Coast Imaging
                      • 3396
                      Its also going to require a resolution switching board A2 when Universal send is going to get installed.
                        • 16083
                        ***think u also need the Resolution Switching Board to enable Send Option with Universal Send Kit
                        Resolution Switching Board is pictured Below
                        It is installed in the second PCI slot from the bottom
