iR 105+ with error code E744-4000
  • Blues Guy
    • Aug 2009
    • 216
    [Error Code] iR 105+ with error code E744-4000
    Have iR 105+ with error code E744-4000 which not listed in service manual.
    Parts have changed HDD and Boot Rom but still appear the same error code.
    Any comment guys ?
  • SCREWTAPE
    East Coast Imaging
    • 3396
    This happens when the DC Controller DIMM from an iR105 is installed into either the iR9070 or iR105+.
    Or did you swap the DC controller from the Ir105??
    • teckat
      • 16083
      Any comment guys ?
      no swap allowed
      • tinnyjay
        • Oct 2009
        • 666
        Any comment guys ?
        Did you cleared errors in SP mode?
        "Who loves the roses,must also bear thumbs"
        • SCREWTAPE
          East Coast Imaging
          • 3396
          That will not help.
          • Blues Guy
            • Aug 2009
            • 216
            You are right SCREWTAPE........problem solved
            • teckat
              • 16083
              22533-Clipart-Ill&#11.jpgSCREWTAPE's Bulb never goes out'
              • SCREWTAPE
                East Coast Imaging
                • 3396
                Glad your up and running.
                Before swapping or replacing PCBs
                Check out the procedures that follow.
                Teckat, your unique.
                • mrfixit51
                  Lead Service Technician
                  • Oct 2008
                  • 1975
                  Well with the flames comin' off his head, the light is always present...
