Help With IR5000 Hard Disk
  • eng_usama
    • 115
    How i can make new hard disk for my canon Ir5000 ?
    my hard disk is dead always E602 003
    please i wanna some help
    thanks
  • kuby
    • Oct 2007
    • 1410
    First you need a compatible hard drive, then you load the system support tool on you computer, then you load and register the software for that machine, then you follow the upgrade procedure in the servce manual exactly. Or you just buy a hard drive with everything already installed. Try Hytec, they may have some.
    • eng_usama
      • 115
      thanks very much for your answer
      but please tell me what u mean with compatible hard drive ?
      i have ide hard disk 20GB and i wanna make that hard Disk
      • KenB
        Geek Extraordinaire
        • Dec 2007
        • 3944
        You can only use certain drives which Canon supports; you can't use just any drive.
        The SST will look for that list of drives when you go to run it, and will fail if your drive is not on the list.
        Or, as Kuby said, you might be able to get a drive with the software preloaded from Hytec.
        • KenB
          Geek Extraordinaire
          • Dec 2007
          • 3944
          Note that these are all "notebook" drives.
          • nivssluck
            • May 2008
            • 228
            You can use any HDD model from 10gb to 40gb. The important is sst and firmware.
            • mrfixit51
              Lead Service Technician
              • Oct 2008
              • 1975
              I can't recall how many times I have replied to this same subject, but it is not as easy as some say it is, nor is it impossible to edit the format.ift file. You need Service Support Tool (SST), and the system software files to load into SST. Then the easiest way to be sure the hard drive is compatible is to Google search for the same model of hard drive already in the copier and buy that model. Or, simply pay too much money by purchasing it from Canon, or you can try NationWide, or Hytec.
              As to how it is accomplished, search this site for the procedures. It has been discussed too many times to count.
              • cdtw9803
                • Aug 2009
                • 51
                it's very difficult to format a new HD on ir2200/5000. it need a very good parrel po
                it need a very good parrell port line.
                • teckat
                  • 16083
                  I Hope~~~~~~~~~~~~~~~
                  • ahmad
                    • Jun 2010
                    • 28
                    hi i can get you meny ir 5000 hdd as you want with sys. on it just tell me if the copier is network or not
                    and if it is old model or new model
                    • teckat
                      • 16083
                      Look Who's in Town bearing Gifts / better be Good ??
                      • ahmad
                        • Jun 2010
                        • 28
                        try me
                        • teckat
                          • 16083
                          try me
                          only if it's >
                          • otreb
                            hard drive
                            need ir 5020-6020 hard drive can you help me yes it is network.
                            • teckat
                              • 16083
                              you need to deal with ahmad, send him a PM/ click on posters name and send a Private Message for your issue
